Is Poly Grip adhesive >= Rescorcinol glue
Brian Rugg
Post by Brian Rugg »
Page 2 of Malahini building guide calls for Rescorcinol type glue. Is Poly Grip from Glen L greater than or equal to Rescorcinaol and be used as a substitute?
Thanks
Brian Rugg
Georgetown TX
& Sturgeon Bay, WI
Just stating a Malahini Sept 2020
Re: Is Poly Grip adhesive >= Rescorcinol glue
Poxy-Grip from Glen L is an excellent structural adhesive for boat building. Poxy-Shield is the perfect adhesive for laminating, sealing and fiberglassing.
Short answer, yes Poxy grip is better.
FL-John
Post by FL-John »
Proxy-Grip is amazing! No mixing in fillers or thickeners. I’m almost through my first gallon and joints that shouldn’t stick without a fastener are stuck tight enough to move the whole boat. Having done the thickened epoxy approach on a kayak I built a few years ago, this stuff is a god send!!!
Post by vupilot »
Poxy-grip for structural assembly, Poxy-shield for fiberglassing or epoxy coating. Poli-Grip for your dentures! :D
Can't tell you how many times I called it Poly-Grip. :lol: :lol: :lol: :lol: :lol:
Brian Rugg
Thanks to all who replied. My bad for mistakenly calling it Poly-Grip instead of the correct name Poxy-Grip. Hope I don't make the same mistake reading the plans :lol: :lol:
Brian Rugg
Georgetown TX
& Sturgeon Bay, WI
:lol: Brian :lol:
As Roberta said, I think most of us have said that before!
Regards, Bill
Return to “Epoxy”
