Ready for glass work
Re: Ready for glass work
Ted had a bad batch mix of epoxy on the middle of one side. He wants to know if he should strip off the whole side or just the bad batch and patch?
I would probably do the patch, try to feather the cut edge and the edge of the patch.
Bluesman
Post by Bluesman »
Thanks Bill. I think it's getting better but I'm not 100% convinced yet, the fabric that overhangs the bottom edge in that section is still pliable. We laid this on last Saturday and I think I'll let it sit for another week to see if it will set up before we go nuclear with it.
I think my helper over mixed the hardener on this batch, maybe the others too but everything else set up properly. Hard to get the mix exact with the scale / ratio containers; I think perhaps the best way to go is to measure by weight instead?
Tahoe - 21' under construction
Ibrew2be
Post by Ibrew2be »
All I ever do is mix epoxy by weight. Just be sure that you use the correct proportions if doing by weight. Some resins, such as System 3 Silver Tip, have a somewhat different ratio by weight than by volume.
Barry
Barry Shantz
Imp built and launched.
Build of Ken Bassett's Rascal currently on hiatus
One thing you can do is to measure the batches out first and have the helper mix them as you go. Then there is not the stress of that person rushing to try to measure out an accurate amount.
Bluesman
Post by Bluesman »
As my friend from Alabama would say, it was a "Miraculous recovery...."
Ted
Looks great!
Bluesman
Post by Bluesman »
Yes, thank you! Really hard to tell where that bad section was at, I had to sand the crap out of it to get the color close to either side of it.
Now onto the bottom and the build up layers...
Bluesman
Post by Bluesman »
More progress..
Bluesman
Post by Bluesman »
And the other side of the bottom is on... Whew!!
billy c
Post by billy c »
Ted that looks real good. Fun stuff to work with. On your next build this will be really easy! :)
Hope your filler coats are going on well.
Billy
Bluesman
Post by Bluesman »
Thanks. First time is always the hardest, it's the unfamiliarity that I hate dealing with. F.U.D...
Bluesman
Post by Bluesman »
More progress..
Forge
Post by Forge »
Wow this is legit!
I love the shape of that hull, and the steep angle on the transom is very cool.
I am about to glass my little TNT so thanks for posting all this.
I am still debating wetting the hull prior to applying glass. But after seeing your results I think wetting the cloth and hull at the same time is totally doable.
Aerospace Engineer, Pilot, Sailor, Tinkerer and Surf Bum
Return to “Fiberglass”
