Dynel vs Fiberglass
Dynel vs Fiberglass
kens asked me about laying up Dynel. My test show it at least 5 times as abrasion resistant. It is not for Bright work.
It cost about the same as glass. It takes a little more resin to wet out. But, a little less to fill the weave.
The scratch is from my testing. This two sides of the same piece of plywood.
This is 6 oz fiberglass
This 5.5 oz Dynel
Cranky Badger
Re: Dynel vs Fiberglass
Post by Cranky Badger »
I've got a bunch of scrap from a job a while ago and I cut most of it into 6" wide tape and I use it to back up butt and scarf joints in panels. For something that's the thickness of a single veneer of the ply, you've got a strength and rigidity that surpasses was a 1/4" butt block can provide - and it doesn't stand proud if you sand out the top veneer where you're laying it up.
And yeah, it's dynamite for abrasion resistance !
I've also been using it as rub strips at the waterline so the bow isn't abraded from beaching. The stuff I've got is around 10 or 12 oz, so it sucks up a lot of resin...but it's well worth it as long as it's employed only where it's needed.
I've got the plans and ply for the 15'6" dory that I'll be building this winter once I get some other stuff wrapped up.
I plan to use Dynel to sheath a small foredeck that'll hold an anchor roller to use for pulling up crab and prawn pots. A red cedar deck sheathed inside and out should ensure that the whole deck absorbs the line pull and not just the area around the roller.
Thanks for posting your results Bill
-Brian
- Yoda
BTW: The test was a standard fire brick, under its own weight, on edge.
It took only 10 strokes to go thru the glass. At 250 I still wasn't thru the Dynel. I got board.
It's best if vacuum bagged. But, I don't do that.
Bill, thanks for posting that.
OK! I lied :!: :oops: It was 52 strokes and 250 strokes. I still gave up.
steve w
Post by steve w »
Bill what weight dynel cloth & were did you get it from. thinking of dynel for my vandal build. boat will be in the water all summer thank you
I used Dynel on the mini tug. I think I found it at Jamestown Distributors. Seems like it has 6 oz.
I think my test was 6 oz. Dynel vs 7 oz. glass. I plan on using it in the anchor chain locker on my new boat.
The biggest down side is that is very difficult to cut.
Return to “Fiberglass”
