fiberglass
korn
fiberglass
Post by korn » Tue Dec 17, 2013 6:28 pm
Hi, I am building the Dinky and was wondering if I should fiberglass the hull before installing the shears or after! Or..could I just run the cloth up to the shear and cut it?
If IT aint broke....don't fix it!!!
tsmitherman
Re: fiberglass
Post by tsmitherman » Wed Dec 18, 2013 6:21 am
It sounds like you are referring to a rub-rail at the sheer (?). Personally, I would glass the hull first and then mount the rub-rail, so that it could be removed and replaced if (when) it gets beat-up.
36' 1969 Willard Aft-Pilothouse Trawler
Blog: www.genesisboat.blogspot.com
Knot-So-Fast (BoJest) SOLD
korn
Re: fiberglass
Post by korn » Wed Dec 18, 2013 8:51 am
Thanks....Tom!!!
Return to “Fiberglass”
