When to Fair Hull?
BlueRidgeBoater
When to Fair Hull?
Post by BlueRidgeBoater » Tue Sep 16, 2014 5:39 am
I've put down three lawyers of fiberglass tape on the hull seams. I'm going to then fiberglass the entire hull. The edges of the tape still have some ridges after sanding. On the inside of the hull, I just faired the tape edges and painted. On the outside, should I fair now, or put the fiberglass cloth down over the entire hull and then fair any remaining ridges from the tape after the cloth and all coats of epoxy have been applied to the hull?
Re: When to Fair Hull?
Post by billy c » Tue Sep 16, 2014 6:57 am
i'd squeege a coat of thickened epoxy along the edge of the tape and blend the seam into the hull. without that step, the glass may bridge the seam and create a void in some areas
BlueRidgeBoater
Post by BlueRidgeBoater » Tue Sep 16, 2014 1:59 pm
billy c wrote:i'd squeege a coat of thickened epoxy along the edge of the tape and blend the seam into the hull. without that step, the glass may bridge the seam and create a void in some areas
Good point. Thanks, and I'll fair with thickened epoxy before fiberglassing the hull. (I was leaning that way anyway, but I'll now feel better knowing I have a good reason to do so).
Return to “Fiberglass”
