Fiberglass resin prep
jeff k
Post by jeff k » Sun Nov 22, 2015 9:16 am
Hi Guys,
I'm a long time epoxy user for glassing on boats. I do not have a whole lot of experience with fiberglass resin. I have a 10' GW Invader I am starting to restore and I will be using fiberglass laminating resin to bed my cloth on the inside of the hull. I will also be using this to glass in the transom and stringers. My question is when using epoxy for this purpose I always have to wash, scuff then wipe down with denatured alcohol between coats of resin to get a proper bond. What process would need to be followed between resin and matt coats with the laminating ( no wax ) fiberglass resin. Do I need to wash it, wipe it or scuff to get proper bond between coats?
Thank you,
Jeff K
This boat project is destroying my wallet, But it is enriching my soul.
Re: Fiberglass resin prep
Post by Roberta » Sun Nov 22, 2015 11:09 am
If you recoat within 24 hrs, you shouldn't have to do any cleaning unless there was some kind of contamination from an outside source.
galamb
Post by galamb » Mon Nov 23, 2015 2:51 pm
Yes, if you catch it while it's still "green" then it will chemically bond to itself.
If it cures then you have to sand (80 grit seems to be the wisdom from the epoxy makers) to ensure a mechanical bond.
Graham
Return to “Fiberglass”
