how much sanding off epoxy spills before 1st layer of epoxy?
Yakima
Post by Yakima » Mon Jul 18, 2016 8:51 am
As you might imagine, I have drips and spots of cured epoxy on the final planks. Do I need to sand that off- more than just smooth it- before rolling on the first layer of epoxy? In other words, will those drips and spots show thru the epoxy?
I have sanded it all nice and smooth, but you can still see where the epoxy ran or dripped when installing the final planks.
thanks!
-Greg
Re: how much sanding off epoxy spills before 1st layer of epoxy?
Post by Roberta » Mon Jul 18, 2016 9:46 am
As long as you have scuffed the surface of the epoxy and cleaned up any amine blush, you will be fine. Scuffing the epoxy will provide a mechanical bond.
Post by kens » Mon Jul 18, 2016 10:31 am
is it clear epoxy resin, or does it have fillers in it?
Yakima
Post by Yakima » Mon Jul 18, 2016 11:05 am
clear.
thanks!
Post by vupilot » Tue Jul 19, 2016 8:47 am
In my experience they will sometimes show through if not completely sanded away
Post by Roberta » Tue Jul 19, 2016 9:03 am
Vupilot is right. If you are covering or painting the area it won't matter. If you intend for the area to be bright finished, then it needs to be sanded to bare wood to ensure a uniform color. Most hull interiors are covered in some way.
Return to “Fiberglass”
