cbrammer wrote:
Thanks for the advise. I could use some pointers on overhead welding to if you dont mind.
It takes a while for me to convince my students that over head is actually the easiest position weld in, but once they get it going good they realize it really is an easy weld to make.
First resist the temptation to turn your machine down, if anything a little hotter than in the horizonital position. Like all welding it comes down to watching your bead tie in to the base metal, controlling your arc, or in the case of MIG, controlling your stickout, then controlling your angles. Keep a close stickout, keep your angle more to the top plate in your weldement, if it is a typical 90 degree fillet weld then use about a 60/30 angle with more emphasis towards the top but keeping your bead equal on both plates. In other words keep the center of the bead in the center of the joint. With the angle more to the top plate gravity will help the legs of the weld equal out. Then you need to use a slight push angle. Keep the wire in the leading edge of puddle and watch the toes of the weld bead tie into both plates.
Honestly overhead is not a difficult weld,,,,,,, the hardest thing is getting in a comfortable position. Learn to relax your arms and don't try to "manhandle" the process. If you do you will get very shaky and unable to control your stickout or angles. Also really concentrate on watching the puddle tie in. In doing so you will quickly learn what you need to adjust as far as your technique.
