It could be a bad camera angle. When I took the photos I didn't have the boat level to the ground. We had just flipped it and I had set some blocks down to protect the bottom. The twist starts between the 4th and 5th frame (near where to 4 sections of bottom plate intersect). When the boat was upside down the twist wasn't there. But could this be from me not setting it up correctly in the forms? Maybe, I cant stay I did a perfect job laying it up (it was my 1st time). But all the frames were cut to accept the longitudinals before I attached them to the forms and when I went to lay the longitudinals into the pre-cut slots everything lined up perfect. So I'm inclined to think its weld distortion from the bottom plates.
The starboard bow was 1" higher than the port side prior to putting in the weight. I pulled the weight out of it this morning and it was down to 3/4" of twist. I am able to get it back to level using weight but getting it to stay there is the trick. I placed weight back in the boat to give it the weekend --- to see it I could get another 3/8-1/2" out of it. The twist is so far up in the bow of the boat I can't get the counter twist applied just where I want it---between the two front frames. I'm having to support the port side of the boat from the transoms to the 3rd frame only. The trailer comes in next week for the boat and using that I should be able to move it to a better location to apply more counter twist to the hull in just the right area.
Im going to take it down to the water and float it before I consider cutting into any of the longitudinals. Once its in the water it shouldn't be visible and on plane that little amount of twist would all be out of the water and not effect performance (vs. 20-30 hours of rework and I hate rework). I'm sure some of the wood boat builders are shaking their heads at me now
