Drilling the prop shaft hole.
Tips for new builders from old builders about things they might have done differently if they had it to do over again.
Moderators: Roberta, Bill Edmundson
Post by Jimbob » Fri Dec 29, 2017 5:26 pm
I wish I had screwed a temporary block of wood on the inside of keel before I drilled the prop shaft hole. I had tearout and the drill bit went a bit off center when it came out. Even though it will be covered up with the shaft log, it still bugs me. If I ever build a boat again I think I might just cut a slot instead of drilling a hole.
JoeM
Re: Drilling the prop shaft hole.
Post by JoeM » Sat Dec 30, 2017 8:43 am
Jimbob wrote:I wish I had screwed a temporary block of wood on the inside of keel before I drilled the prop shaft hole. I had tearout and the drill bit went a bit off center when it came out. Even though it will be covered up with the shaft log, it still bugs me. If I ever build a boat again I think I might just cut a slot instead of drilling a hole.
Good tip. I'll have to keep that in mind when I get there. Thanks!
Post by kens » Sat Dec 30, 2017 10:02 am
What kind of bit did you use?
Drill bit? forstner? hole saw?
I them all, and found a hole saw to be the best,
Yes, you need a tear-out block, preferrably on both sides.
Rich Coey
Post by Rich Coey » Sat Dec 30, 2017 2:33 pm
Here is a link to a post that showed the hole saw I made. Easy to make, cut through fast, and it cuts straight and won't wander like a drill bit.
viewtopic.php?f=2&t=25179&p=151163&hili ... aw#p151163
Rich
Return to “"I Wish I Had..."”
