Motor mount width
weller
Motor mount width
Post by weller » Sat Jul 07, 2012 12:43 pm
Anyone know how far apart the motor mounts are on a 350 and a 454?
"My mind is on a permanent vacation, the ocean is my only medication"
scottinwv
Re: Motor mount width
Post by scottinwv » Sat Jul 07, 2012 1:19 pm
This thread from a day or two ago will probably answer all your questions:
viewtopic.php?f=9&t=16447
fergal butler
Post by fergal butler » Sat Jul 07, 2012 2:06 pm
This is for a 5.7 should be the same as the 350 http://wwwarchive.mercurymarine.com/upl ... 864759.pdf
weller
Post by weller » Sat Jul 07, 2012 4:48 pm
Thanks. The reason I asked is because I set my motor stringers for a 350, and now I might use a 454. Just wanted to make sure it would work. Thanks again.
Post by kens » Sat Jul 07, 2012 5:52 pm
Doesn't matter if it a 350, 454, Cummins 6BT, or a Detroit diesel. Install the standard width inboard stringers and you can choose whatever engine you wish.
neel thompson
Post by neel thompson » Sun Jul 08, 2012 3:43 am
If you space the stringers so that you have about 26" between them ( Inside of stringer to inside of stringer), you should be fine for either the 350 or 454. You will then bolt/epoxy motor bed timbers, three or four inches wide, to the stringers for the motor mounts to actually sit on. You can find many pictures of this setup on the forum....Hope this helps....Neel
weller
Post by weller » Sun Jul 08, 2012 8:34 am
Thanks guys. I spaced them at 26" but wasn't sure if a big block would fit between.
jamundsen
Post by jamundsen » Sun Jul 08, 2012 5:55 pm
BBC fits fine.
John Amundsen
Monte Carlo
Lakeland,Fl
Return to “Boat Power”
