Buick/Rover 215 aluminum v-8 exhaust manifolds
Lil Jon
Re: Buick/Rover 215 aluminum v-8 exhaust manifolds
Postby Lil Jon » Sun Dec 02, 2012 8:44 am
Just an update on this project- I already have the casting boxes built and am starting on the outside log pattern.
Postby kens » Sun Dec 02, 2012 9:36 am
those also fit the 300 Buick, correct?
hugger69
Postby hugger69 » Sun Dec 02, 2012 2:57 pm
Lil Jon wrote:Just an update on this project- I already have the casting boxes built and am starting on the outside log pattern.
Sounds great Jon! :D
Are you planning any kind of logo on them? :wink:
Best regards,
Hakan in Sweden
www.hakansmotorsida.com
Lil Jon
Postby Lil Jon » Sun Dec 02, 2012 7:26 pm
Kens--
I'm not sure about the 300 Buick? next time I talk to Mark at D&D I'll ask him.
Lil Jon
Postby Lil Jon » Sun Dec 02, 2012 7:31 pm
hugger--
Logo-- we considered that over the past couple of weeks and come right back to the same thing, use my last name just like Vic Edelbrock did on his products----
MYERS
hugger69
Postby hugger69 » Mon Dec 03, 2012 2:54 am
Lil Jon wrote:hugger--
MYERS
Great! :D
...please make it look old school like the Offenhauser valve covers I showed before in this thread! 8) just put the name MYERS instead of Offy! :wink:
Best regards,
Hakan in Sweden
283cuin
Postby 283cuin » Mon Dec 03, 2012 4:03 pm
This may not be news, but seller br549junior has a set of Edelbrock manifolds on e-bay
Buy it now $2,000. I could not find an item number and can't do the link thing.
hugger69
Postby hugger69 » Tue Dec 04, 2012 5:06 am
283cuin wrote:This may not be news, but seller br549junior has a set of Edelbrock manifolds on e-bay
That´s a lot of money for something that´s even broken ones....? ;)
Better to buy new ones from Jon! :D
Best regards,
Hakan in Sweden
Lil Jon
Postby Lil Jon » Wed Dec 05, 2012 2:22 pm
I ordered a pair of Glenwood elbows today. The #708 with 80 degree bend and a 4" flange. I need to have a set in my hands just to make sure my log diminsions will work with the Glenwood elbows and risers. I will wait on delivery before I start on the log pattern.
hugger69
Postby hugger69 » Thu Dec 06, 2012 7:27 am
Great that you keep us updated here Jon! :D
Keep up the good work, Jon!
I guess we are a bunch here that´s eager to hear from you progressing! :wink:
Best regards,
Hakan in Sweden
hugger69
Postby hugger69 » Mon Dec 10, 2012 8:03 am
Anything to report yet? :wink:
Best regards,
Hakan in Sweden
Lil Jon
Postby Lil Jon » Tue Dec 11, 2012 9:49 pm
I received the elbows from Glenwood today. That was fast shipping and service!
Here is a photo of the elbows with a pair of Graymarine aluminum 215 manifolds. The Graymarines have a few added bosses on them that won't be on my manifolds, plus the water will enter and exit from the front end of the manifold and not from the top like these show.
I am going to be busy on another project at work for the next couple of weeks and probably won't be able to get back to work on the pattern for the manifolds until after Christmas.
Jon
hugger69
Postby hugger69 » Wed Dec 12, 2012 8:26 am
Thanx for the update, Jon!
I´m not sure if I understand how the water is going to flow through the manifolds and out through the riser/elbow yet....?
I´m having a closed water cooling system with a heat exchanger so maybee it´s just the return fresh water from the exchanger that will run through the riser/elbow and mix with the exhaust fumes in my case?!
Sorry, I have to ask cause I´m a newbee on this type of installation... :oops:
Best regards,
Hakan in Sweden
Lil Jon
Postby Lil Jon » Wed Dec 12, 2012 6:02 pm
You are correct. With your closed cooling system the fresh water picked up with your sea pump will go through the heat exchanger and exit through the elbow or riser to help cool the exhaust hose and it also helps silence the exhaust noise. Your permanent antifreez/coolant will enter the manifold on the front end of the manifold through a plate that will bolted on to cap the manifold and water jackets and it will then exit through the same plate. The 1/2" pipe thread holes in the plate will align with the water jackets in a way to promote water to flow from front to back on the top side of the manifold then from back to front on the side and bottom of the There might be a photo of a rectangular manifold with this type of water flow in the Glenwood online catalog.
hugger69
Postby hugger69 » Thu Dec 13, 2012 6:11 am
Thanx for a quick and correct answer, Jon! :D
Best regards,
Hakan in Sweden
Return to “Boat Power”
