I need advice on rebuilding a Merc 500 from 1962
AaronB79
Post by AaronB79 »
I have a Merc 500 from 1962. The previous owner said he was running it on his boat last year, then it lost spark. I'd like to rebuild it, but first I want to get it running to be sure it is worth the effort. Any advice? Are repair manuals available for this engine? Any experts, books, websites, or other sources of info you would recommend?
I'm planning to build a boat to match this motor, most likely a Zip. Any help would be greatly appreciated.
Aaron
galamb
Re: I need advice on rebuilding a Merc 500 from 1962
Post by galamb »
You could get a manual and some parts from Laing's outboards (upstate NY/Buffalo area) http://www.laingsoutboards.com/
If the (distributor) magneto ignition is toast on this you have 1) a paper weight 2) a can of worms that could take you years to put the lid back on
You might be able to get ignition parts from Twin City Outboards - recycled, expensive, but sometimes the only source - http://www.twincityoutboard.com/
Personally, I would check compression and spark - if both are good then a fuel issue can be corrected. Carb kits are still available for this model (about 80 bucks a carb), but that is certainly do-able.
If you have ignition issues I would be tempted to part it out, sell what you can and search for another model.
In the world of older outboards some models can be restored without a lot of trouble, this is not one of them if you need anything more than the most basic of parts. An OMC from the same era would be a better candidate for a restore if you want a 60's motor.
Graham
AaronB79
Post by AaronB79 »
Graham,
Thanks for the reply. I was afraid that this may be a tough one to fix. I jumped into buying it without doing much research. I'll check the compression and spark and if the outlook is bad I'll throw it on craigslist and focus my energy on building the Zip.
Aaron
fergal butler
Post by fergal butler »
I bought one of the later blue bands and swapped over the cowling you get the classic look and the engine is easy to get parts for :D it might be another option for you to think about.
AaronB79
Post by AaronB79 »
What is a blue band? Which years? I'm interested in the newer engine, older look hybrid, thanks
fergal butler
The blue bands were built between 72 - 83 named after the decals, they are still getting on in the years :D but there are lots of them about.
AaronB79
Post by AaronB79 »
How easy/difficult was swapping the cowling? Does it only work with the blue band years?
fergal butler
It's a straight swap on any of the wrap around cowls blue,red and brown but it won't work on the clamshell cowls. The engine must also have the same number of cylinders as the one the cowling came off.
AaronB79
Post by AaronB79 »
That's great. I'm going to explore this for sure if my engine turns out to be no good. Which components should I keep from the old engine? I would sell off the remaining parts.
fergal butler
All the shinny bits :D I think someone on here also did it with an Evinrude
AaronB79
Post by AaronB79 »
Thanks again. I was disappointed that I may not get the look I wanted for my boat. You have given me new hope and I'm very excited. I can have an engine that looks the way I want and one that I can service, it's perfect!
Aaron
fergal butler
Mine is a 50 hp with a 400 face plate.
I also have plans to do a few more when the right engines come up.
It's starting to get a bit out of hand now :lol:
Post by gdcarpenter »
Compression test #1 job - if 120 psi +/- engine innards pretty good and worth further investigation, if low, the unless you want to tear down the engine, part it out.
Dropping the magneto and if not replacing, at least filing, cleaning and gaping the points, hopefully replacing the condenser, doable to try and get spark.
cusoak
Post by cusoak »
Her are a couple of sites that have parts and service manuals. And a Merc. forum with a lot of information.
www.johnsoldmercurysite.com/phpBB3
http://www.johnsmcintoshvintagemercuryoutboard.com/
I used them to help me get my merc 400E 45 hp running.
Jeff
AaronB79
Post by AaronB79 »
fergal butler wrote:Mine is a 50 hp with a 400 face plate.
It looks like you have a few good projects in the works! I think these engines look great on a homemade Glen-l boat, I just can't wait to get started with mine!
Return to “Boat Power”
