powering flying saucer
vintage
Post by vintage » Wed Jun 03, 2015 12:04 pm
Just curious if anyone knows if a 3hp outboard will push a 12 foot flying saucer and what I might expect from it. It may be a while before I can afford a bigger motor.it will be for pond use only most likely. I also plan on making the boat light as possible. Any help would be appreciated. Thanks. The motor is a 1966 johnson 3hp.Thanks.
Andy Garrett
Re: powering flying saucer
Post by Andy Garrett » Wed Jun 03, 2015 12:38 pm
I imagine it will push it, but it won't get on plane.
One of the comparably shaped hulls built in the stitch-and-glue technique might be both lighter and more appropriate for a small tiller motor.
Andy Garrett
vintage
Post by vintage » Wed Jun 03, 2015 1:43 pm
Thanks for the reply. The flying saucer is already in the works and i will eventually get a bigger motor. I'm hoping a mercury super 10 will get it to plane if I can ever find one.
Pullie
Post by Pullie » Thu Jun 04, 2015 5:18 am
I once used a 4HP 4-stroke to limp home after my 20HP died. I got to 12km/h but think that there may be a little bit more possible with a better prop. for planing I think you need at least 10 to 15HP.
chugalug
Post by chugalug » Thu Jun 04, 2015 6:13 am
:D My brother and sister used to waterski behind a 16 ft. alumacraft and an old 10 horse Johnson.try that with a new one. :D
Post by Hercdrvr » Thu Dec 31, 2015 6:02 pm
Keep saving up $$ and get at least 20 HP. My 2 cents
Post by vupilot » Fri Jan 01, 2016 10:27 am
A 15hp would do excellent on a flying saucer. The 3hp will putt you around the lake though and beats watching from shore 8)
Return to “Boat Power”
