what size transit/cable pipe for Yamaha 115hp outboard?
Re: what size transit/cable pipe for Yamaha 115hp outboard?
Post by Bill Edmundson » Wed Sep 07, 2016 6:41 am
Peter
My 115 Yamaha just got installed. Throttle and shift on the 115 are the push/pull type cables. I got the digital gauge set up. I'm going down to the boat it a little while, I'll measure. I think it's 2 1/2" or 3". It's wad of cables. I uses Bay Star hydraulic steering.
Post by Bill Edmundson » Wed Sep 07, 2016 7:54 am
Peter
No external pump other than the squeeze bulb. They said when I switch tanks the first time that the engine should pull the fuel. But, I could help it with the bulb. I probably won't need the bulb unless I run a tank dry.
I know several people with this engine and all are happy with them.
Post by Bill Edmundson » Wed Sep 07, 2016 11:09 am
Peter
Let's see if this is any help. It looks like everything will go through a 2". But, life will be easier with 3" or more.
viewtopic.php?f=2&t=12277&p=181804#p181804
Post by Bill Edmundson » Tue Sep 20, 2016 6:57 am
wolters
You can use a vacuum cleaner to pull a string through the pipe. Then make continuous loop of string. Then use the string to pull wiring.
Return to “Boat Power”
