Hemi
bob smith
Hemi
Post by bob smith »
Just sitting around dreaming.......
A Hemi powered Torpedo, hmmmm I wonder what it would take to marinize a modern 5.7 Hemi?
Anyone know about the compatability of a velvet drive with a TKO or Tremec bolt pattern?
Exhaust manifolds would probably have to be fabricated.
Just trying to stir thing up a bit :)
Bob Smith
Chester, SC
Re: Hemi
It would be way cool to see another Torpedo with any appropriate power.
Roberta :D :D :D :D
bob smith
Re: Hemi
Post by bob smith »
True but the bar is up there so high.
Bob Smith
Chester, SC
bob smith
Re: Hemi
Post by bob smith »
Still musing......
The mating of transmission to engine.
Any ideas??
Bob Smith
Chester, SC
Re: Hemi
Does the new Hemi still maintain the old style Chrysler bolt pattern?
Back in the 60's the Chrysler was THE way to go for torque. There was thousands of them mounted with velvetDrive.
DSR
Re: Hemi
Post by DSR »
I believe the Gen 3 Hemis use the same bolt pattern as the LA small blocks minus the center top bolt. The flex plate/flywheel is different but the aftermarket hot rod guys have already gotten that covered. That would be a very cool package! 8)
Codename "Just A Little....."
viewtopic.php?f=23&t=29753
Re: Hemi
bob smith
Re: Hemi
Post by bob smith »
Wow,
I'm checking it out. It can't be that simple. Whose tranny did Chrysler use?
Bob Smith
Chester, SC
Re: Hemi
VelvetDrive was the most common; it don't really matter, Paragon and others all used the "BorgWarner " bolt pattern.
As long as you get the BorgWarner pattern (Velvetdrive) you can bolt up a Paragon, ZF, Hurth, TwinDisc, etc., etc.
Re: Hemi
here another one, if you can part it out; you might end up with a free bell housing plus some tranny mounts.
http://www.ebay.com/itm/318-Chrysler-Ma ... Q3&vxp=mtr
Re: Hemi
it looks like the wet exhaust manifold will be the killer.
Here is a link to all the chrysler exhaust gaskets (bolt patterns), and they look different from the old heads to the new hemi heads
http://www.ttiexhaust.com/Category-Misc ... langes.htm
DSR
Re: Hemi
Post by DSR »
Fab some water-jacketed stainless manifolds like Jenko did for his V12 Jag engine?
bob smith
Re: Hemi
Post by bob smith »
I'm still "researching" the feasibility of using a gen3 Chrysler hemi as a boat engine.
Some of the pros are:
Way cool aspect
Torque/hp/weight
Availability
The cons include:
Lack of marine exhaust manifolds
Complexities of the engine management system
I haven't uncovered a "show-stopper" yet. The good news it gives me something to "chew on" while not thinking about more mundane things.
I wonder what it would sound like???
Bob Smith
Chester, SC
DSR
Re: Hemi
Post by DSR »
Hi Bob,
For what it's worth, there's stand-alone engine management systems out for the Hemi that are pretty much plug-and-play. There's also the options of intakes for a carb and plug-in ignition control modules too......
Am I helping at all? :lol:
Re: Hemi
Some of these exotic engine installs are way cool, but I am too simple minded to experiment too much. Just give me a simple package that fits standard stuff so I don't have to re-invent the wheel. :lol: :lol: I'd rather spend my time on getting in the water with a cool exterior. :lol: :lol:
Roberta :D :D :D
Return to “Boat Power”
