Help with Prop Selection
indyillini
Post by indyillini »
I am completing my build and need to add a prop to my motor. I have built the Overniter and have installed a 2016 Mercury 4 stroke 90HP Gearcase ratio 2.07:1. I have tried the online calculators and have been getting recommendations all over the place. Can someone offer a recommendation on what I should start with? I am leaning toward a 4 blade diameterXpitch 13.5x15. Does that sound reasonable? Thanks for the help.
Re: Help with Prop Selection
Indy
What is your max. RPM? (WOT). I think your going to be able to get to about 38 MPH.
indyillini
The Full throttle RPM is 5000-6000.
I'm seeing about a 13 or 14 pitch. You may need a 3 blade to get to RPM. The dia. seems a little big for a 90 hp. But, I don't run a Merc.
I worked off of 5500 RPM.
Congrats on nearing the end of your build!
Return to “Boat Power”
