Questin about fresh watercooling
gostap
Postby gostap » Tue May 08, 2018 12:28 am
Hi;
I have a Mercruiser 260 that I want to install fresh water cooling. Does anyone know if it's possible to use a brazzed plate heat exchanger instead of the more common tube exchangers?
Bg
Gostap
NAMEngJS
Re: Questin about fresh watercooling
Postby NAMEngJS » Wed May 09, 2018 7:27 am
It should be possible, as they operate under similar thermodynamic principles, the concerns will be two things:
1) does the heat plate heat exchanger cool the circuit effectively. The vendor should sell you a product that meets those needs but best to make sure. And to make sure that it fits inside the envelop of the engine compartment.
2) Pressure losses through the system. With a closed loop system you will have 2 pumps, one for the sea (lake, river, ect) water and one for the jacket water system for the engine (freshwater cooling medium) plate exchangers have much higher pressure losses for the system compared to tube exchangers so the pumps would have to be sized up and will in turn will be more expensive (propbably) and require more energy to run them.
You may have to do some arm twisting but the vendors should have this data available for you and you can determine which option makes the most sense for you.
gostap
Postby gostap » Thu May 10, 2018 2:34 am
thanks a lot for answer, maybe better to use a tube-exchanger..
Return to “Boat Power”
