General outboard questions
Craig Aho
Re: General outboard questions
Post by Craig Aho »
hooked up a battery and now no the starting circuit are working from the motor controls and also did a compression test. I have a cylinder that is quite low compared to the other 3 so not sure I can start or use this motor. A real disappointment for sure.
Craig Aho
Post by Craig Aho »
Nearly ready to try to start the old girl. I did the compression tests and just need some fuel and barrel of water. It was suggested to me that with the old motors we should run only fuel without the ethanol. I located some about a mile away and will use that in my boat and maybe start using it in my old 240Z car as well.
Craig Aho
Post by Craig Aho »
Thought of another question with regards to the throttle and shift cables from the helm control. My cables on the unit are way to long and I am planning to buy new cables but reading different instructions am not sure how much extra cable to add to the basic run dimensions. Some say 1.5 ft. others say 4 ft. Does anyone have experience changing out there cables, How much extra is needed?. Also I assume I just reuse my old connections from each end of my current cables? meaning the cables you buy are just threaded rods on the ends to accept whatever your boat motor needs? thanks all.
Craig Aho
Post by Craig Aho »
Well looks like I lucked out and my cables are just the right length. Spent a bunch of time rerouting and determined all is correct and routed as best I can without drilling more holes in my nice wood boat.
An option to drilling more routing holes is to create decorative covers. For example, I bet a very nice cover could be made to match up to the back of the throttle control.
Craig Aho
Post by Craig Aho »
Wow I didn't even consider that Idea Carl, Thank you.
Craig Aho
Post by Craig Aho »
Can anyone recommend a good book on vintage outboard motors and restorations etc.?
Do a Google search or hunt on Ebay. Often you can find original service and repair manuals in hard copy or download versions for vintage motors.
Craig Aho
Post by Craig Aho »
Thank you Roberta, I did as you suggested. I am thinking I might like to aquire a few outboards to refurbish and collect. I just wish my son Chris was nearby and not living in Phoenix since he is a trained motorcycle mechanic so I could have his help. Those old Merc's have my interest and look so cool.
Craig Aho
Post by Craig Aho »
Since this is my first experience with an outboard motor, does anyone see any problem with my fuel line plumbing? It was kind of time consuming trying to decide and install some kind of attachment fittings. I finally settled on this quick connect setup.
Craig
Try this guy and see if he has any manuals you could use.
http://www.johnsmcintoshvintagemercuryo ... nuals.html
Craig Aho
Post by Craig Aho »
Thanks Roberta. Cool stuff on his site.
After I posted, I realized you don't have a Merc, but site is helpful to those that do.
Post by billy c »
Craig Aho wrote:Since this is my first experience with an outboard motor, does anyone see any problem with my fuel line plumbing? It was kind of time consuming trying to decide and install some kind of attachment fittings. I finally settled on this quick connect setup.
Craig
You could do that. Is that a Seachoice tank fitting? If so that is really made for the tank end. What I'd do if you are not taking the motor off very often is go direct with the hose to the fuel filter on the motor and make the quick release at the tank. (or if built in tank eliminate all together.
Billy
Craig Aho
Post by Craig Aho »
Thanks Billy C. I have been told the original used a chrysler style fuel hookup which I think is what I bassically have at this point. I like your thought though on the line direct to the filter.
Return to “Boat Power”
