Chriscraft 283 Mounts
boisebrit
Post by boisebrit »
All,
I am building a key largo and currently rebuilding a Chriscraft 283 motor for it, and wondering does any one know where to get new engine mount bushings as they are not a common size.
Attached pic of the bushing total of 6 required, front has 1 per mount and rear two per mount, plus pic of motor in progress.
Thanks all
TAB
Re: Chriscraft 283 Mounts
Post by TAB »
What are the diametions?
boisebrit
Post by boisebrit »
They are 2 1/4" outer diameter, by 1 3/8" inner and just over an inch long, with an outer steel casing, rubber interior stuck on a steel bushing. They were frozen to the mounts and I destroyed 1.5 trying to get them off to get accurate measurements.
I tried a commercial company that has similar but did not have the size, they could make a mold for $1200.
I now have a solution I hope I am making my own, I have found bronze bushings that match the inner diameter and steel pipe for the outer. I can then use a kit to poor my own internal bushing, Should be into for the grand total $55 for all six bushing's. This the same method used for making your own suspension or engine mounts.
If you have other ideas or solution let me know and thanks for replying, these things are a very unique size.
boisebrit
Post by boisebrit »
So have now completed manufacturing my own engine mounts - steel tube from a muffler extension, some brass bushings and a urethane kit.
Few little lessons on the way, but now have all bushings made - About $65 in total. Pic of old and new attached.
If anyone needs more details let me know.
steveh41
Post by steveh41 »
Looks like problem solved... great job!
Return to “Boat Power”
