It is currently Sat May 18, 2013 5:43 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Jul 30, 2011 8:23 pm
Mike - That is gonna be sharp.
dave
PostPosted: Sun Jul 31, 2011 5:45 am
Looks Great!!!
Roberta :D :D :D
PostPosted: Sun Jul 31, 2011 10:31 am
Anybody ever try brass, aluminum, pewter, nickle/silver, or other soft, non-ferrous metal for this application?
Palm might give good texture.
For something really off beat, how about rubber or delrin?
Just spitballing...
Andy Garrett
PostPosted: Sun Jul 31, 2011 11:16 am
I think I will pass on your suggestions Andy. While I am a bit off the wall, I try to keep things relatively simple, wood on wood, or even resin seams for clearcoated decks thats going to sit in the open elements part of the day. Rubberized stuff is not real friendly to varnish overcoating, from my previous observations.
PostPosted: Sun Jul 31, 2011 6:48 pm
fredt wrote:
I am extemely new to this, actually just started, but I have seen a few posts where wood strips, maple, etc, were used for the deck seams. Because black sounds so appealing, would there be any reason that ebony couldn't be used? (except for price)
Also, are your seems kept flush with the deck boards or recessed?
Hi Fred: Wenge might be a less expensive alternative to ebony for seams. A little wilder grain pattern, but gives you the same dark contrast. Usually very straight grained where I find it as well.
Ken Hundley
- Stevie Ray Vaughan
PostPosted: Mon Aug 01, 2011 12:50 am
:lol: :lol: :lol:
Yea, metals and plastics probably wouldn't expand and contract favorably to wood.
I bet a nice white Holly would be awesome though! I've used it for knife handles. It can be fairly hard and has a very durable straight grain.
Andy Garrett
PostPosted: Mon Aug 08, 2011 3:04 pm
I was going to pester Roberta some more on her thread, but since this is up and going, I'll add to the questions.
If you are using solid stock to plank the deck and some sort of paste caulk to fill the gaps, what is the best method to ensure that the gaps are perfectly even?
My first instinct is a router, but how do you prevent wandering bits?
Do you put down the king-plank and cover-boards first--route them--then remove them so you can repeat the procedure for the field-boards? Then, you reinstall everything with the glue?
I'm just having a tough time getting my head around the best (read: most efficient) procedure.
Andy Garrett
PostPosted: Mon Aug 08, 2011 3:37 pm
I layed out the king plank and perimeter planks, then I started at the king plank using 2 3/4" wide boards. I cut the ends to match the curve of the perimeter and king plank and used 1/4" tile spacers to keep the boards 1/4" apart. Each was temporarily screwed down with drywall screws. Once everything was fitted, the boards were removed and reinstalled with epoxy and SB screws. Plugs were installed over the screws. I will use System Three Gel Magic and a white pigment for the caulking. Doing that tomorrow.
PostPosted: Mon Aug 08, 2011 8:42 pm
I've been following this thread hoping for inspiration as I keep musing over my future decking, a ways away that it is.
Been wondering about using wider planks, say 2 1/2" or so, butting them tight, but doing an inlay stripe down the middle of each board, anyone ever try that approach?
PostPosted: Wed Aug 24, 2011 12:09 pm
Well the deck is sanded to a uniform surface and wiped down. One more last sanding with the fine tooth paper and the stain goes on.
PostPosted: Wed Aug 24, 2011 12:15 pm
Very Pretty Mike!!!!
http://www.unitybuild.net
PostPosted: Wed Aug 24, 2011 12:20 pm
That is going to be a DAZZLER!!! WOW!!!
Roberta :D :D :D :D
PostPosted: Wed Aug 24, 2011 5:44 pm
Unique idea with the planks angled, havent seen that before. Creative and nicely done as usual.
My Zip build log...
PostPosted: Wed Sep 21, 2011 12:12 pm
While many were out playing with their woodies after shaming me and my original staining job, I was sanding, sanding, and sanding some more and reapplying shiny linseed oils to my wood. 8)
Personally I am liking the dark enlays more after each coat of finish work.
PostPosted: Wed Sep 21, 2011 12:23 pm
Another fun project that I have been doing was to resaw my 20 foot mahogany and created a bookmatched raised coaming. Those also are now being finished off the boat in the buildup process before I install them. This also gives me free run of blocking out the side decks.
fitting the caoming on the inside the boat and sidedeck curves took a bit of patience since you have to compress the board into the side decks and check the angles. The 13 inch wide board ends up to being a ccurved boomerang shape with the sweep of the side decks and freeboard rise.
the raised sections is the location of duel conosle setup for the walkthrough windshield and the foward seating.
