It is currently Mon May 20, 2013 2:12 am
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Tahoes on plane
PostPosted: Sun Aug 07, 2011 4:41 pm
Just took our Tahoe out for its first sea trial this past weekend and had a wet surprise, am wondering if any of you have had a similar experience:
We built the "extended" version of the Tahoe and have powered her with a PleasureCraft 351 / Velvet Drive transmission. The drive angle is set up for 15deg. The actual waterline is close to spec as she sits about 2-3" higher in the water at the stern than expected. Should point out that we are using a small temporary fuel tank (there's no weight from a full tank in the stern).
At idle, she's pushing a lot of water off the bow and, when we throttle-up, the bow-wave is breaking very, very far forward, probably only 2' back from the bow which makes for a very wet cockpit. At speed, the bow-wave rolls back to where I'd expect: about mid-engine compartment. Same experience coming off-plane. There's a lot of spray coming in to this boat and I don't think a windshield's gonna help.
We're planning to add some ballast in the stern to see if that helps.
Any ideas?
 Post subject: Re: Tahoes on plane
PostPosted: Sun Aug 07, 2011 4:49 pm
Congratulations on the launch.
I don't know about the Tahoe.
With the Monaco, I found I was occasionally "catching some spray" in the transition. I find that upwind starts can be wetter than downwind starts. I also find that the faster you get to a plane, the better.
Other than that, I have no meaningful advice for you.
Bruce.
Dow's Monaco Project
PostPosted: Sun Aug 07, 2011 4:52 pm
:lol: Yes the Tahoe can be a wet boat :!:
The plans say the spray rail is optional. It's not. I learned from Butch Barto. He soaked me coming off plane. Add the spray rail. It will give you a couple of MPH and keep you drier.
PostPosted: Sun Aug 07, 2011 5:24 pm
Thank you for the quick replies, much appreciated. Bill, you're referring to the spray-rail specified in the plans (the one that stretches from midships to stern) ? I could see that helping the lucky ones in the rear cockpit, but what about the front?
PostPosted: Sun Aug 07, 2011 5:52 pm
Corey
Run the spray rail at the chine all the way to the stem along the chine. It makes a world of difference. The lower side of the rail runs 90 degrees to the hull.
PostPosted: Sun Aug 07, 2011 6:14 pm
Butch told me about this at the last Gathering. Could you post a picture of yours?
John Amundsen
Monte Carlo
Winter Haven, FL
PostPosted: Sun Aug 07, 2011 6:17 pm
Thanks again Bill, that makes sense. Am looking over some pictures of older runabouts and see the "full-length" spray rail on the Shepherds, Centurys and Correct Crafts. Any recommendations on depth of the rail?
Will find Butch Barto's pics online and have a look.
-C.
PostPosted: Sun Aug 07, 2011 7:20 pm
My rails are 1" thick off the hull by 1 1/2" tall. Makes a world of difference.
PostPosted: Tue Aug 09, 2011 9:37 am
Uh Ohh... Thats not good. Im building the tahoe 23 stretched 10% and wasnt planning on installing spray rails other than the ones in the rear connecting them to a swim platform.
So seems like rails all the way to the front is a must??
Does anyone have detailed pics?
Regards
PostPosted: Tue Aug 09, 2011 10:00 am
The ones that Butch put on this Tahoe were at the chine and I didnt notice them until he pointed them out.
John Amundsen
Monte Carlo
Winter Haven, FL
PostPosted: Tue Aug 09, 2011 12:08 pm
Butch installed his after studying mine. Look thru the pics of Gathering 2007 you can see my boat, the big white center console. The rails do 2 things; knock down spray, and, break the water off the topsides this is where you pick up speed & rpm.
Butch mentioned he gained couple hundred rpm.
PostPosted: Tue Aug 09, 2011 2:47 pm
Those pics r too small but i get the point.
Now do they run along the chine all the way to the back?
Do you just epoxy them on or do you drive screws thru also?
How are they supposed to give you extra rpms?? :?:
Thanx fellaz!!
PostPosted: Tue Aug 09, 2011 2:56 pm
My sprayrails are the full length of the chine. I used screws and bedded with 3M4200. The rails actually turn down slightly. That gives the boat a little lift, seems lighter there for less drag and more rpm/more speed.
PostPosted: Tue Aug 09, 2011 4:06 pm
are they the same as the optional ones on the plans??
PostPosted: Tue Aug 09, 2011 4:15 pm
Yes, sometimes they're called chine guards.
