It is currently Tue Jun 18, 2013 2:37 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: cuddy sport
PostPosted: Wed Nov 02, 2011 4:34 am
got all my lumber. WOW what a truck load,a bit overwhelming! Got the stem cut and laminated, I'm officially started :)
 Post subject: Re: cuddy sport
PostPosted: Wed Nov 02, 2011 5:04 am
Let the fun begin!!!
Roberta :D :D :D :D :D :D
PostPosted: Wed Nov 02, 2011 5:51 am
what? no pile-o-lumber pics??
:wink:
Jeff
My Celerity build.
PostPosted: Wed Nov 02, 2011 8:55 am
That's called a boat in the raw. Now, all you have to do is remove the not boat.
PostPosted: Thu Nov 24, 2011 9:12 am
Well finally got all my frames built :D , cant wait to get them in place on the building frame. one question though.would it be easyer to barrier coat them know or after I right the hUll ?
PostPosted: Thu Nov 24, 2011 9:19 am
It's easier to do it now.....less drips,and easier access.
PostPosted: Thu Nov 24, 2011 9:24 am
Looking good!!! If you do barrier coat them before assembly, remember to rough up the areas for the glue joint, unless you glue them up within a day or so.
Roberta :D :D :D :D
PostPosted: Thu Nov 24, 2011 5:26 pm
Whoa! That Barn is just too big and too clean and too well organized, and maybe too well equipped.
Better move the boat out in the yard where it can be born n' bred in it's lifetime circumstance! :P
Looking back now, I wish that I'd have built a Cuddy when I was so active in Puget Sound and then taken it to Alaska with me.
It's an 'all around' good fishing boat for dang near any water.
How many nights I spend under a tarp out on the water, when for a few Bucks more I could a had that little Cuddy for comfort n warmth. Heat it with a Candle, that little Cuddy.
Good choice buddy.
PostPosted: Mon Dec 19, 2011 1:41 pm
OK How close is close enough. dont know if Im a butcher or a perfectionist. started off giving myself a plus or minus 1/32. Well had to revise that tolerance :lol: .so got all frames,stem, breasthook and transom lined up,squared, and plum. checking every way i know how looks like Im 1/8 to 3/16 out over the whole 24 feet. Is this close enough?
PostPosted: Mon Dec 19, 2011 1:48 pm
Looks and sounds good to me....weather will change that tolerance that much.
PostPosted: Mon Dec 19, 2011 2:01 pm
yep every thing looked good till I warmed up the shop. then it went all over the place. weather stinks in ohio this time of year. 50 degrees one day and 20 something the next. heat with wood and is hard to regulate.
PostPosted: Mon Dec 19, 2011 2:04 pm
Looks Great and those tolerances sound just fine.
Roberta :D :D :D :D
PostPosted: Sun Jan 08, 2012 5:43 pm
Im cutting in th chine log. It is a 1'' x 2 1/2'' member. It looks like I am going to be fairing about 50% of it away in the bow area. does this seem normal?
PostPosted: Sun Jan 08, 2012 6:18 pm
I know on my Zip the part of the chine that gets faired for the bottom planks gets faired quite a bit.
PostPosted: Mon Jan 09, 2012 5:09 am
well every thing look right, just seems that that is the area that should be heavier,not thiner. worst comes to worst I could laminate a piece on the inside could'nt I ?
