It is currently Sun May 19, 2013 7:50 am
 Post subject: Transom jack
PostPosted: Mon Jan 02, 2012 9:31 am
Happy New Year
I have started building another Zip. Does anyone have any experince with transom jacks?
Chipper363
 Post subject: Re: Transom jack
PostPosted: Mon Jan 02, 2012 10:37 am
Hey Chipper.
I used one on a 14'SK flatbottom with a 1500XS Merc.
It added some top end, but wanted to fall off a plane at slower speeds real bad.
I pulled the plate off and mounted the motor flat on the transom (15" with plate even with bottom) and had a 2-3 MPH slower boat, but it was more usable for most boating.
I was told by some local hot boaters that I should have run the motor higher on the transom, but didn't really have the money to experiment with props etc to get things right
There also is a jack in racing(or was years ago) that extended through the transom and supported the lower unit....some of these were manual adjusted for trim, and some were hydraulic depending on the size and complexity of the boat....I don't think you mean this though and am assuming you mean a jack plate to raise straight up & down
PostPosted: Mon Jan 02, 2012 10:46 am
Chipper, you might find this guide interesting, if not helpful:
http://www.antiqueoutboardmotor.info/Ga ... elt_1.html
Users browsing this forum: Google Feedfetcher and 1 guest
