It is currently Fri May 24, 2013 12:20 am
 Post subject: Will I fit in TNT?
PostPosted: Sun Jan 22, 2012 11:20 am
Hello,
I'm interested in building 2 passenger outboard boat. So far I like TNT best. My only question is, being 200lbs :oops: 5'11'' and girlfriend is 5'4'' and 120lbs..do you guys think that both of us will comfortable fit in TNT?
Thanks in advance and...I'm sure that I will have more questions soon.
 Post subject: Re: Will I fit in TNT?
PostPosted: Sun Jan 22, 2012 7:44 pm
I think the TNT would work BUT I would look at the BULLET. The Bullet is wider, only 15 lbs heaver and will take up to a 40 hp motor. Also for 320 lbs of passengers, the 40 hp motor would be a better power plant. I have the plans for the TNT and it has a flat bottom not a Vee Bottom the Bullet has a true Vee bottom not as much as I would like, but it should give a decent ride. I currently have a 13 foot flat bottom boat that is a fun ride but it is a rough ride in moderate chop.
PostPosted: Sun Jan 22, 2012 7:48 pm
A guy who goes by BulldogBoater has a jet Squirt and he is 6' 2". I think you'll fit fine.
http://www.youtube.com/watch?v=Cg4brYZfJPg
PostPosted: Mon Jan 23, 2012 3:08 pm
I'm 6'3", 215 and I'm building a dyno-jet...
PostPosted: Mon Jan 23, 2012 4:49 pm
Sounds good. I think I will build the TNT then. I just love the way it looks...now I need to find some good but relatively inexpensive wood within 300miles from Chicago, IL
PostPosted: Tue Jan 24, 2012 12:40 pm
You can also extend the TNT by a foot to give yourself a little more interior room.
Check here for the lumber: http://www.glen-l.com/resources/lumber- ... rs.html#IL
Jeff
My Celerity build.
PostPosted: Wed Jan 25, 2012 11:15 am
I built a Squirt and it's fine. It's only a little snug because I put in a tilt wheel.
I still don't have that cleat for the stern I may have to reorder it.jpg [ 2.38 MiB | Viewed 507 times ]
If you really want some room, do what I did next. Build a Stiletto. :D
On the other hand, you could just build a Minimax and leave everyone on the dock, :D :D :D
34706_164560366892137_100000145238889_602152_5374515_n.jpg [ 114.92 KiB | Viewed 507 times ]
