It is currently Wed Jun 19, 2013 3:42 am
PostPosted: Fri Feb 24, 2012 1:14 pm
Finally found my lumber. I bought 300 bd ft for $.60 per bd ft. He let me sort through the wood at my own leisure. Very happy right now with what I got.
Brad
PostPosted: Fri Feb 24, 2012 8:11 pm
Very good It is Douglas and not lodge pole.
14' Mr John-Wild Flower 2
Rod H
PostPosted: Sat Feb 25, 2012 3:37 am
The fir is OK for frames and straight timbers/frames, but IMO and from my experience is absolutely terrible for battens. It doesn't bend well, doesn't fair at all and splits and splinters when you try to dress it or even belt sand it when fairing.
PostPosted: Sat Feb 25, 2012 12:29 pm
It's douglas fir for sure. He sells it for flooring but is letting me go through the rough cut stuff before it gets milled.
Brad
PostPosted: Sat Feb 25, 2012 4:12 pm
Not sure I have very many other options. Mahogany and white oak is 7$ per board foot.
Brad
PostPosted: Sat Feb 25, 2012 4:53 pm
Brad; I would suggest that any battens you have to bend much that you laminate them up in 1/4" layers. This will definately help. For fairing you're better off with a belt sander than a plane.
PostPosted: Sat Feb 25, 2012 6:14 pm
sounds good. thanks for the tip.
Brad
