It is currently Wed Jun 19, 2013 8:39 pm
 Post subject: Crap!
PostPosted: Fri Mar 30, 2012 2:37 pm
I hate to say this but i caught a mistake ! frame 7 is out of line and i had the bottom battons glued down.now im trying to get it right .i moved it a bit and eyeballed it about 50 times and i think ill go with it. it was to far out on one side,maybe a half inch.others are fine. cant believe i did that :!: :oops:
 Post subject: Re: Crap!
PostPosted: Fri Mar 30, 2012 2:42 pm
Trim down the outside one and add a shim to the other& don't tell anyone!! :wink:
PostPosted: Fri Mar 30, 2012 2:54 pm
Too late i already cut though the glue line and moved it .im going to put :!: the chine on temp. and if its got a fair curve ill go forward. cant see how i did that !! chine on both sides of course !!!!!!
PostPosted: Sat Mar 31, 2012 1:55 am
I did much worse, all of my frames where out by about 5mm on one side. Don't panic, cut it off, fix it up and move forward.
If I am anything to go by, it won't be the last time you screw up, wood is particularly forgiving that way, pretty much anything you mess up you can fix with a bit of epoxy
Building a Monaco....provisionally called "Serenity"
http://glen-l-monaco.blogspot.com/
PostPosted: Sat Mar 31, 2012 6:54 am
See my tag iLne! OOps! Line.
PostPosted: Sat Mar 31, 2012 7:36 am
Thanks ,it looks good now and im just eye balling it. its hard to measure because the battans are on. so i was measureing from the center of middle bottom battan and toward the outer edge of the frame. :?: :idea:
PostPosted: Sun Apr 01, 2012 5:58 pm
Svenole,
Thickened epoxy will cover a multitude of sins. I think I have about 7 shims on my chinelog, but as far aong as I am on the Little hunk, NOBODY will ever know but me.
Keep plugging, It is good to hear that you are back in production again!
Seiner
Users browsing this forum: Google [Bot] and 2 guests
