It is currently Fri May 24, 2013 1:02 am
Post new topic Reply to topic  [ 174 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11, 12  Next
 Post subject: Re: CRACKER BOX
PostPosted: Sat Nov 19, 2011 5:47 pm
Nice!!! If I build something else, there will definitely be some red on it somewhere. I suppose a flip is just around the corner.
PostPosted: Sat Nov 19, 2011 7:43 pm
Arrest me Red. Ready in Red. Whatever you call it, it looks great!
My Zip build log...
PostPosted: Sat Dec 10, 2011 11:01 am
Drilled out the hole for the prop shaft :D , I had been putting it off a bit just incase things went wrong.The angle was worked out from the engine setup and then marked on a bit of scrap wood where I drilled out a hole to take the extension bar holding the 2" bit, I also put a block of wood on the keel inside and out the same angle as the bit to give the tip a starting point and so it would not start walking when it came through. I went this way as I haven't got my strut made yet.
All in all it went well except for the sawdust and smoke under the boat from drilling a 10" x 2" hole in mahogany while lying on your back, in the end it came out spot on target I now have to epoxy in a fiberglass tube to seal it up and then cut it down to size
I started making the strut from 10mm stainless steel just have to get the tube to hold the cutlass bearing and weld them up and give it a polish.
PostPosted: Sat Dec 10, 2011 11:08 am
You do great work Fergal!!! :D
PostPosted: Mon Feb 13, 2012 7:45 am
The new strut cut out and welded up.
I just have to sink it a bit more into the hull and then fiberglass it up along with the prop tube that will hold the stuffing box.
It will be a bit tight fitting the rudder but should fit :shock: it will be offset 1" to the side so the prop shaft can be removed, after the filling is done I will do another 3-4 coats of paint and a good polish.
Well this is the way it's turning out "it just might work" :lol: I think I will just flatten out where the plate is on the rudder and recess it to let the water have a smooth run by.
PostPosted: Wed Feb 15, 2012 6:10 pm
Fergal.
What are the dimensions of your Skeg and prop?
Are you building the standard length or the extended length?
Time.
Eat less move more.
PostPosted: Thu Feb 16, 2012 4:14 am
Hi Time, the skeg is 4"x5"x6" high the strut is 14 degrees with a 6 1/2" drop and the prop is 13x13 four blade I didn't pick this prop it came with the donor boat so I have no idea how it will work.
I am building it standard length :oops:" extra 10% would be handy" with a V8 chevy and a 1-1 gearbox I don't think it has been done before with an inboard rudder so only time will tell how it rides :D
PostPosted: Fri Mar 30, 2012 1:49 pm
I moved the boat forward by putting a few bits of pipe under the building frame and just rolled it out, next I added two 8 foot lengths of 4x2 to the boat to use as handles and to keep it off the ground.
It was a bit tight on one side :D
Sorry no photo of the turn as my hands were full, but with the help of 3 mates and a few beers we got her on her side then lifted it up from the bottom and over she went.
For the first time she is looking like a boat but I had not got enough room to take her for a spin :lol:
PostPosted: Fri Mar 30, 2012 1:53 pm
Looks great Fergal,what's the Merc going on?
PostPosted: Fri Mar 30, 2012 1:57 pm
I haven't decided yet. :lol:
PostPosted: Fri Mar 30, 2012 2:01 pm
80 or 50? (or whatever other HP they made offshoots from a 4 cyl)
PostPosted: Fri Mar 30, 2012 3:53 pm
Congrats on the flip milestone.
My Zip build log...
PostPosted: Fri Mar 30, 2012 4:24 pm
Very nice Fergal--that's a true DIY'er who makes his own boat hardware!
Gayle Brantuk
Vice President
Glen-L Marine
PostPosted: Fri Mar 30, 2012 4:57 pm
Oh yea, I forget about the flip toast!!!
PostPosted: Sat Mar 31, 2012 1:37 am
I'd like to add my congratulations too Fergal. Great work on your build and your self crafted hardware, nice welding job, but most importantly your flip ! It's certainly a milestone that I remember well...........loads more fun ahead mate.....enjoy !!!
Tim
:? Forgetting you've been there before, just watched your Malahini launch, how windy was it that day......or is it always that windy ?
Users browsing this forum: Aussie and 0 guests
