It is currently Sat May 18, 2013 6:00 am
PostPosted: Wed Apr 11, 2012 6:28 pm
The building notes for the Console Skiff (and guessing probably all of the stitch & glue designs) states:
"The LAMINATE SCHEDULE, on this sheet, calls out two types of fiberglass laminates, BI-AXIAL (BA) E grade 17 oz. and 7-10 ounce cloth (C) commonly used in boat covering."
I've identified two different sources for the biaxial tape with one being the Glen-L boatbuilder's online supply store:
http://www.boatdesigns.com/Non-Woven-Biaxial-Tape-per-Yard/productinfo/S3-183/
The prices for the 4", 5", & 8" mat-backed tape is $3.10, $3.90, and $6.00 respectively. I'm sure that this is a top quality product just like everything else I've bought from Glen-L, but based on my calculations of what I would need to purchase and cut to size will run over $300. Not cheap for my budget but I would happily pay that if there is a clear benefit to using a mat backing. I would greatly appreciate any comments on the value that mat backing adds to the taping/reinforcement process. Does it make it significantly easier/faster/cleaner/stronger/better looking/etc?
The other source is an ebay vendor that would total a little more than a third of the above costs. It looks like the same material sans the mat backing but then again I'm not 100% sure from their limited description. Will post this source if anybody has used an ebay sourced tape and if posting a link to that source doesn't violate any forum rules.
As always, thanks in advance for any and all comments.
Try to build something that is idiot "proof" and you will simply expose a different group of idiots...
PostPosted: Thu Apr 12, 2012 10:09 am
TX_Aggies,
The tape version of bi-axial cloth is very expensive. You can also buy the 50" cloth version by the yard and cut it to the widths you need--it's messier, but it's what we've done here before we found tape.
http://www.boatdesigns.com/Bi-Axial-Cloth-50-Wide_yard/productinfo/08-200/
The bi-axial cloth is not "mat backed" and that's not necessary. Like I said, this is what we used to build the test model.
Gayle Brantuk
Vice President
Glen-L Marine
