Can you provide us with more info about your boat and engine installation ?? Is the gear ratio 1:1 or is this a reduction unit ? Strut drop, shaft angle, and propeller diameter would also help. Is the lack of space in the engine compartment a hatch clearance issue ??
Note that as shaft speeds increase, the maximum universal joint operating angles of 3.5 degrees can be significantly reduced e.g. 3.5° @ 3500 shaft RPM, 2.75° @ 4000 shaft RPM, 2.2° @ 5000 shaft RPM. (See
Universal Joint Alignment Procedure For Passenger Cars).
Robert Hankins posted some photos of his TINY MIGHT in Customer Photos. He's coupled a CV joint to the flywheel of a 120 HP Honda Civic engine. Adapting to the transmission output flange should be straightforward but more space will be required to mount a thrust bearing cage and CV joint. Steep angles will lead to u-joint longevity issues and possible failure resulting in damage to the boat and/or passengers.
An
Aqua Drive system may work but they're expensive and I haven't seen any reference to maximum angle. Here's a link to their
Price List. Better be sitting down before clicking that link ...
A better option would be to use an inline 8° down-angle transmission such as a
ZF 45A,
ZF 63A,
PCM 40A or Velvet Drive
Liberty Series transmission. Refer to our
Transmission Page for specs and suppliers.
If all else fails, a flywheel-forward engine with Velvet Drive C71 transmission is the ticket if space is at a premium. Click
here to see a shaft layout diagram for a 15 foot boat. Engine CG is 70" from the transom and the shaft angle is 13.5°.
_____________________
Paul Kane
Kane Custom Boats Ltd.Chelsea, Quebec
Building the Glen-L Hot Rod :
http://www.kanecustomboats.comGlen-L Boat Video Directory :
http://www.kanecustomboats.com/pages/vi ... ctory.html
