Flying Saucer Build
Mojo
Re: Flying Saucer Build
Post by Mojo » Tue Sep 02, 2014 1:47 am
Looking great. Coming along quick.
Cheers
Mojo
miyot
Post by miyot » Fri Sep 05, 2014 6:52 pm
Power up and pushing on.
[attachment=0]IMG_8967.JPG[/attach
miyot
Post by miyot » Sat Sep 06, 2014 6:19 am
vupilot wrote:What size is the motor?
Its 25 HP. Heavy at 180 lbs. The transom carried it well, especially with the transom saver on. I could detect no flex in the transom with the transom saver on while hauling, nice and solid. However without the transom saver the transom could be flexed if you bounced the engine. This much weight will require a motor well to help reinforce the transom. I was happy with the engine install. Now back to work.
travis24
Post by travis24 » Sat Sep 06, 2014 6:24 am
Looks great project is progressing well. I would get the motor well built before setting the motor I'm sure that's you plan. Great job so far.
Travis
Measure Twice, cut Once.
https://waterhogsworks.com/
miyot
Post by miyot » Mon Sep 08, 2014 6:03 pm
My seats are as low as I can get them. I want a short windshield with a hard top so they must be as low as possible. The supports run on top of the battens and slant aft from station 4, so the seating is lower than the top of frame 4. The seat backs will be slanted back as well. The hard top will have a hatch in the center so you can lift it and step in between the two seats to sit down. It will actually seat three across, but the center seat back will be removable for easy entry and I'll rarely have three across so the seat back will be stored.
I'll have no cross beam to support the seat backs so I'll have to rig some kind of supports for the seat backs. The center seat back will slide onto the side seat backs and get its support from them. I don't want to have to step over to get seated. Getting in will be hard enough with the hard top.
miyot
Post by miyot » Sun Sep 14, 2014 5:39 pm
Some progress. Cedar decking on the bow and the side decks are ready to install.
geneanthes
Post by geneanthes » Mon Sep 15, 2014 6:14 am
Is that teleflex steering? Which kit did you get?
Boat looks great!
-Gene
Me: GeneAnthes.com
My day job...Criminal Defense Attorney in Austin: GBAFirm.com
Tubby Tug Build: Taylor's Tug
miyot
Post by miyot » Mon Sep 15, 2014 10:26 am
geneanthes wrote:Is that teleflex steering? Which kit did you get?
Boat looks great!
-Gene
Thanks Gene. My Merc dealer ordered the steering for me. It is Teleflex, it says Safe T.
Cabron
Post by Cabron » Mon Sep 15, 2014 10:54 am
I like what you did with the seat base. It looks like you are sitting in the boat
rather than on it.
miyot
Post by miyot » Wed Sep 17, 2014 6:07 pm
Finished installing the gunwales and have started on the windshield.
miyot
Post by miyot » Sun Sep 21, 2014 3:46 pm
Windshield is a little large compared to traditional Saucers, but you are completely protected behind it. I have decided not to put a hard top on it. Getting in would be difficult and it would have to be a little higher than it is now and would look a bit odd. And I am ready to finish up this project and get it on the water. Rounding the corners of the window frames will make it look a little better.
miyot
Post by miyot » Thu Oct 02, 2014 6:12 pm
Well it is nearly done. I have to paint the interior and run wiring and lights and finish the seating and install the glass which will be installed with the dark Mahogany around the windows. I took a week off for water skiing and a trip to Canaan valley. The boat will have taken about 9 weeks from the time I received the plans to the finished boat. All of scrap wood.
miyot
Post by miyot » Sun Oct 05, 2014 2:34 pm
Window trim and interior paint and she is finished. Next weekend, sea trials. Yea!
Post by vupilot » Sun Oct 05, 2014 5:27 pm
Pretty amazing that you built this in the amount of time you did, it looks great! I'd love to see some video of it with that new 25 pushing it along when you take it out.
