Matt's Geronimo
Re: Another Geronimo Coming Soon
Post by mrintense » Sun Nov 09, 2014 6:44 pm
I saw this same keel curve on my hull when I was at that point. At first I thought it was wrong but checking the plans on my boat confirmed that it was okay. But I did spend a lot of time trying to get this area correct. I can only hope that I did so! :)
Your boat is coming along nicely.
Carl's Vera Cruise Build
Post by Bill Edmundson » Sun Nov 09, 2014 6:47 pm
Looks and sounds like you have this figured out.
Post by hoodman » Mon Nov 10, 2014 6:03 am
Ha, I've had plenty of time to read Boatbuilding with Plywood, Boatbuilders Notebook, and the plans. I've also read through several of the great builds here on the forum. Still learning a ton as I go and having lots of fun with it. The wife is fully supporting me which is a big help. We have our first little one (boy) coming in March and I would love to get the boat planked and righted by then. We'll see.
Post by hoodman » Tue Nov 18, 2014 5:30 am
Anyone have any ideas how to keep a hand drill plumb while drilling? I'll need to drill out for the keel - transom and keel - stem bolts soon. I had one hole that was way off center when I was drilling the transom knee for the transom connections. I was able to fix it but I'd like to avoid that happening again.
Post by Bill Edmundson » Tue Nov 18, 2014 7:29 am
To keep the drill straight I drilled a hole in a piece of scrap 2x4 on the drill press. Then I drill a starter/locator hole in the piece. With the 2x4 as a guide I can get the hole started true. Usually have to stop and remove the 2x4. By then the hole is deep enough for the bit to stay true.
Post by hoodman » Tue Nov 18, 2014 7:47 am
great, thanks!
Post by hoodman » Mon Nov 24, 2014 6:17 pm
The keel is now installed! Chines are scarfed together, I glued them this morning and installed the keel this evening. I decided to take advantage of the warm weather for gluing.
Nomad_19
Post by Nomad_19 » Mon Nov 24, 2014 7:13 pm
That looks great! Is Geronimo a scaled down Sea Night hull? I seem to remember Rory telling me it was.
Luke Hargenrader (nomad_19)
My current ride is a 1963 Thompson SeaLancer "Miss Morning Wood"
Re-building "The Betty Boop" a Glen L-Nomad built by my father in 1973
Have plans for Vera Cruise and Double Eagle....maybe someday.
Post by hoodman » Mon Nov 24, 2014 7:56 pm
I believe it is the same hull. I am building mine to 17' so it is basically a sea knight without the cabin.
Cabron
Post by Cabron » Tue Nov 25, 2014 1:41 pm
Man your moving along quickly. Looks great! I bet you`re having the time of your life.
Every step on my ZIP build is a complete thrill. Lovin every minute of it!
Post by hoodman » Tue Nov 25, 2014 2:23 pm
Chines are clamped in place so I can see where I need to cut angles in the frame notches. They seem to be coming in right on the money at the chine blocking on the stem.
Cabron, I am having a blast!
darthplywood
Post by darthplywood » Tue Dec 02, 2014 12:00 pm
she's looking great....this is where the boat really starts to come to life!
yet to come...11' Glen-L "Utility"
bjfrater
Post by bjfrater » Tue Dec 02, 2014 12:22 pm
Looking good!
It really starts to take the shape of a boat once you get those longitudinal pieces attached. Very satisfying.
Post by hoodman » Sun Dec 14, 2014 3:02 pm
Made a scarfing sled to do the scarf cuts on the sheer clamps on the table saw. I found a super easy design for it online. One of those things where I'm thinking "why didn't I think of that." Should work for stock up to 2 1/2" wide which rules out the battens on my design. Maybe I can tweak something to make it work.
Post by mrintense » Tue Dec 16, 2014 11:34 am
I've seen many different ways of doing this scarf joint. I ended up using a router and two angles wedges to lay the router plate on.
I may have to come up with something to scarf plywood for a portion of my bottom skins.
