Mid year Titan progress
Cool Runnings
Re: Mid year Titan progress
Post by Cool Runnings » Tue Oct 22, 2013 10:18 pm
Greetings-Thanks for the glass advice Doug of which I'll adopt and I'll expect it expensive here as well. There is no point in using an inferior type of glazing that may stove in from a wave.
Good to hear from you finally Carlos!-Good luck with Carioca.
The engine used is Kubota based three cylinder rated @ 30HP and marinised by Beta Marine.
I have good expectations with the Kubota having owned other equipment with the same motor.
For instance, a loader of mine with 5500 hours and apart from oil changes, has not had a spanner on it.
A 15 year old ride on mower has had similar work and no faults either.
The Beta has an anode on the heat exchanger whereas Nanni variant does not and was a cheaper package overall. Gearbox is Twin Disc with 2:1 reduction.
Regardless of who you go with, it is best to get a basic control panel and then add the additional gauges(Oil, temp, fuel etc ) yourself. It will save over one thousand dollars I found.
Otherwise lots of varnishing going on here and starting on the cabin door.
Regards-C.R.
El Jefe
Post by El Jefe » Wed Oct 30, 2013 7:28 am
Hard to go wrong with a Kubota. Keep the oil and fuel clean and it should last forever in a pleasure boat. Its sad how many diesel engine owners, especially sailboat owners, don't keep up on maintenance.
Rick
Cool Runnings
Post by Cool Runnings » Sun May 17, 2015 6:01 am
Hi all-Still plugging away on the Titan, although considerable time was lost from a guy who was looking after the hull painting.( I do not have the gear or location to spray paint).
Anyway getting on with the interior fitout, engine/shaft is installed and now at lock-up stage to the exterior.
Exciting times and hoping to launch late June, all going well.
Hope you enjoy the pictures.
Post by mrintense » Sun May 17, 2015 1:44 pm
Wow, impressive work. If possible can you post some more pictures of the boat?
Cool Runnings
Post by Cool Runnings » Sun May 31, 2015 1:42 am
Pushing along nicely here-Some electricals done and the hydraulic steering is operating as of today.
Some more parts due in tomorrow and next deal is the cooling circuit(engine) and fuel lines etc.
Some more pics as requested.
Regards-CR.
Possibly fire up the engine for the first time next weekend-Can't wait!
Cool Runnings
Post by Cool Runnings » Sun May 31, 2015 2:48 pm
Cool Runnings
Post by Cool Runnings » Thu Jun 04, 2015 1:24 am
Cool Runnings
Post by Cool Runnings » Thu Jul 16, 2015 4:03 am
Hi all-Finally got all the electrics sorted and funnily enough all the gear works.
There was one small lead left off the back of the starter motor and took a while to figure out why the engine would not turn over.
Got that fixed and after bleeding the fuel twice the little Kubota came to life. It runs with very little vibration and after engaging the gearbox in forward/reverse, everything is operational-A BIG DAY!
We put a barrier coat on the underwater sections with antifoul now to follow.
The handrail goes on tomorrow along with some deck tread up forward.
At this point expected launch is for this coming Wednesday.
Gayle Brantuk
Post by Gayle Brantuk » Thu Jul 16, 2015 7:39 am
Beautiful! Look forward to seeing launch photos. Congratulations :D
Post by Bill Edmundson » Thu Jul 16, 2015 8:00 am
Me Too :!:
Cool Runnings
Post by Cool Runnings » Thu Jul 23, 2015 5:01 am
Greetings all-Thanks for your positive comments.
As it is winter here, timing is everything and we launched the Titan in favourable conditions today.
I cannot speak highly enough of the plans,as the boat sits perfectly level in the water and to it's designed water line.(This has got to be every boat builders dream)
There are many a disaster in this harbour where yachts and power boats have not gone to plan. I know and used to own one, back in 1988.
The 30 Hp Kubota runs smooth and the PSS shaft seal presented no problems.
Best day ever!
Post by Bill Edmundson » Thu Jul 23, 2015 5:52 am
:D :D :D
Gayle Brantuk
Post by Gayle Brantuk » Thu Jul 23, 2015 8:52 am
That's so great to hear and wouldn't be the first time. I really look forward to seeing photos of your beautiful boat!
Cool Runnings
Post by Cool Runnings » Fri Jul 24, 2015 4:38 pm
Hi all-Not having the opportunity myself to take pictures during the launch,I have relied on others to send me over some photos.
Hope you enjoy.
Regards.
Cool Runnings
Post by Cool Runnings » Fri Jul 24, 2015 4:42 pm
