Frearson vs. Square Drive Poll
What kind, options, etc.
Do you prefer Frearson or Square Drive Silicon Bronze Screws?
Poll ended at Thu May 12, 2016 11:42 am
Frearson
3
23%
Square Drive
10
77%
Total votes: 13
Adrock1
Re: Frearson vs. Square Drive Poll
Post by Adrock1 » Sat May 07, 2016 4:34 am
I voted square drive just because I've found them much less likely to strip. Honestly though I've had no issues with the frearson screws. I use a dewalt tapered bit and countersink to drill the holes. I drive the screws with with a regular #2 Phillips bit in my 12volt Milwaukee impact driver. I haven't broken a screw yet.
For those who haven't used an impact I highly recommend picking one up. They work very well. I suspected it would be more likely to breaks screws but I've found the opposite is true.
graham mackay
Post by graham mackay » Tue May 10, 2016 3:51 pm
Square drive every day, and that's not just because I'm a Canadian!
I am presently constructing a Glen-L HERCULES, hull basically complete.Am going to fiberglass and paint bottom and then turn over. Sides to be planked with10mm yellow cedar edged bead and cove . Engine is Mitsubihi 4-cyl. 39 crankshaft hp.
Mark-NJ
Post by Mark-NJ » Tue Jun 14, 2016 10:34 am
I finally got some square drive screws....what a difference!!
Agreed: they don't have a "classic look", but for ease of use (zero tearout of the heads), these are much better than the Frearson.
