I guess it's time to come out of the closet!Bartender 24
Re: I guess it's time to come out of the closet!Bartender 24
Postby Bill Edmundson » Fri May 05, 2017 6:33 pm
Pete
Good idea. I didn't install the system, Yamaha Warranty. I don't know exactly what it looks like and how much work it would be. I'm sure I could do it. But, with the boat 400+km from home my work time is limited. I lost my work time to the weather this week.
Edit: I might be able to come off the cold side of the kill switch.
Postby Bill Edmundson » Wed May 31, 2017 7:47 am
Had more bad weather last week. But, I did make a gain. The top I want will cost a bunch. And, getting somebody to do it has been a problem. This one is $165 on Amazon. It will get me out of the sun. Working in the boat lot in the sun at 85* and 85% humidity really knocked me down.
I found a new problem so maybe I did make a gain.
BIll
Postby Roberta » Wed May 31, 2017 8:04 am
That's looking good.
Postby mrintense » Wed May 31, 2017 8:08 am
Nice addition to the Bartender Bill. And $165.00 isn't bad for a price. Did that include the tubing? I am assuming it did.
Postby Bill Edmundson » Wed May 31, 2017 8:13 am
That's everything, frame, hardware, and Bimini. I put it on backwards so it will fold up to the top of the windscreen and be out of the way.
Postby DrBryanJ » Wed May 31, 2017 8:47 am
Looks good Bill. Great find and clever solution going backwards.
jenko
Postby jenko » Wed May 31, 2017 3:25 pm
looks custom made for it
Postby Bill Edmundson » Mon Jun 12, 2017 6:19 pm
I'm getting frustrated. Lauren invited more people to go out on the boat. I told her I hasn't ready with the boat. I have less than 10 hours on the boat. I'm still learning it. I had a low level in the starboard tank. The port thank is full. I switched to the full tank. The boat ran good down to the pick up point. We started out and everything was good. Then the engine shutdown!
A good Samaritan gave us a tow, about 3 miles. He wave off any compensation. It's what good boaters do. If your ever in the Gulf Shores/ Orange Beach AL area, please buy fuel at Bear Point Marina. The guy owns it. We were his second tow of the day.
I switched back to the starboard tank and after a few pumps the engine fired right up. Glad it's not the engine. I don't know why it's not pulling from the other tank.
I'm also going to have to rework the main deck.
jenko
Postby jenko » Mon Jun 12, 2017 7:17 pm
I feel for you Bill added pressure not what you need while sorting out the finishing nuances
Postby mrintense » Tue Jun 13, 2017 5:57 am
My first thoughts would be either plugged somehow, or a leak in the line preventing the vacuum from forming on the pull side of the fuel line. Another possibility, clogged filter, bad fuel pump (if separate)?
Postby Bill Edmundson » Tue Jun 13, 2017 6:15 am
The fuel pump is form the engine. Both tanks feed through one filter. The starboard tank feeds fine. May be operator error at the valve. :roll:
I'll also check the vent and for a pinched line.
chugalug
Postby chugalug » Tue Jun 13, 2017 7:04 am
we have a little problem with mud-dauber wasps clogging up little holes.your fuel vents have screens on ,I hope.
Postby Bill Edmundson » Tue Jun 13, 2017 7:36 am
Chug
We have that problem down here, too. That's why I mentioned the vent. I seen people loose a day, thinking they had cooling water problems only to find the pee hole full of dirt.
chugalug
Postby chugalug » Tue Jun 13, 2017 7:51 am
seems I read on here somewhere about marine fuel line with liner that can get wadded up when installing. :roll:
raymacke
Postby raymacke » Tue Jun 13, 2017 5:06 pm
So Many Rivers,
So Little Time....
Users browsing this forum: No registered users and 16 guests
