Roberta's Torpedo
Re: Roberta's Torpedo
Post by Hercdrvr »
My deck is all wood, in the picture you can see one of 1/4"maple strips of wood separating from the mahogany.
Denon Osterman
Post by Denon Osterman »
Hey Roberta, quick question on the trim tabs - why did you opt for them over the more traditional "turnbuckle cavitation plate" style (see below pic)? Ease of adjustment?
And Bill - Do you know if the need for expansion is mitigated if the "subdecks" are made of the same or similar wood than the main one? I personally was going to do a "caulkless" top...but now you've got me worried. :shock:
P.S., Not sure I've managed to say this yet, but a huge congratulations to Roberta on your work! That is one beautiful boat, and made even more impressive given you helped to finish the design! Very well done :)
Post by Roberta »
Thanks, Denon!! A couple of reasons for the Lenco tabs. The Torpedo transom curves quite a bit and I though the linkage might bind or get complicated. I did want to be able to vary the settings easily for changing loads as fuel depleted in the very aft tank. And the Lenco's seem simpler to install, especially in a completed boat.
Roberta :D :D :D :D
Denon
On a sunny day on the Gulf coast the temperature on top of a dark deck will burn you. The underside of the sub-deck will be warm. The difference makes for a lot of stress.
Denon Osterman
Roberta, that makes sense on the tabs. I'm still debating if I should add cavitation plates to mine...but that's still a little ways off!
Bill, that makes sense. Hopefully up in (much cooler) Canada I don't run into the same issue...though I suppose only time will tell. My mahagony covering is also only "veneer" thickness, i.e. 1/8" (and less when sanded), which will hopefully help the issue somewhat...though now I'm all worried :shock:
WayWard
Post by WayWard »
I just finished going through this thread again.
I may have a problem..... :)
Post by Roberta »
My biggest problem was convincing my husband I needed to build it. I truly love this boat and all the attention it gets.
WayWard
Post by WayWard »
Just wanted to add that while I am in the planning/ambitious dreaming phase. This thread is incredibly helpful in that it provides a lot of insight into the build process to force me to think about how best to deal with some of the complications of boatbuilding.
This is such a detailed thread, it is immensely valuable. Everything is so beautifully documented. I expect I'll read through it a few more times before I get around to starting. As I learn more and more leading up to my hopeful build, I'm able to glean new insights into particular build phases
Thanks Roberta!!
jenko
Post by jenko »
congrats on another trophy :D
svenole
Post by svenole »
Something isn't right there.
:roll:
Post by Roberta »
What!! :lol: :lol: :lol:
tborg
Post by tborg »
Hi Roberta,
I saw in the picture posted in the lates Glen-L email that you added hydraulic trim tabs to your torpedo. Was there issues that brought you to that modification?
tborg
Post by Roberta »
Actually, they are electric Lenco trim tabs. Higher speed above 35 mph tended to raise the bow up to a point where rough water would cause the boat to porpoise. The tabs allow me to adjust the bow height and smooth out the ride at high speed in rough water. I can exceed 50 mph without porpoising and the boat handles great.
chugalug
Post by chugalug »
:D I read the comment you submitted to"Woodyboater" on the Cobra.I like your boat far more than the "Cobra".It's got that funny looking bulbous bow,whereas yours is alot smoother and I was not too enthused on their fin -yours came out perfect.Just my opinion. :D
Post by Roberta »
Who could argue with such wisdom!!! Thanks, Chug!!
Roberta :D :D :D :D :D
