Monaco Restart
Hurra912
Re: Monaco Restart
Post by Hurra912 »
Great thread! Definitely going to follow.
speedracer
Re: Monaco Restart
Post by speedracer »
I am trying to figure out how to get the bow plate made. No one around here could handle such a task. I was wondering if anyone knows of a firm that might fabricate these if a wood or fiberglass pattern were sent to them.
I also posted this request in the "Material - Metal" section of the forum.
Any help will be greatly appreciated. Chris.
psychobilly
Re: Monaco Restart
Post by psychobilly »
BayouBengal
Re: Monaco Restart
Post by BayouBengal »
Many people get these made by Mike the Cutwater Guy - http://www.cutwaters.com/
He has videos on his site that show you the pattern he needs and how to order one, and from there it's not too hard to decipher how to make one. My brother and I made mine. There's a fair amount of work in it and so I can assure you that if you could get one made by Mike, for what he charges, it's well worth just paying him to do it. However, there's a catch, he'll not make your cutwater if you have a bow eye.
If you don't want to make it yourself and Mike won't make it, I suggest that you look for a local street rod builder/fabricator.
If you're cutwater shopping, you must be getting close. Looking forward to seeing you on the water.
FFRCOBRA
Re: Monaco Restart
Post by FFRCOBRA »
Just installed my cut-water from Mike Sunday. Fit perfectly.
I sent him the patterns (from his videos) and then picked up the parts (I only live about an hour away from him) a few weeks later.
Highly recommended!
Craig
Re: Monaco Restart
Post by Roberta »
Mike does a Great Job and his cost is very reasonable. He made the cutwater for the Torpedo and the Zip for me as well as the transom bands for the Zip. I think he can make most anything out of Stainless for you. Nice guy to work with and very conscientious.
Roberta :D :D :D :D
speedracer
Re: Monaco Restart
So many helpful responses - thanks so much.
I took a quick look at Mike's youtube videos and the process he has outlined to send him a pattern looks fool proof. Although I may prove that wrong. Anyway, that looks like the way to go except I am a little concerned that there can be no bow eye. I am used to using that to finish loading the boat at most launches and keep it tied down to the trailer after loading. Maybe I'm missing something here.
Roberta - Your cutwater is just what I want - not too pronounced and flared at the top.
Bayou Bengal - I am not really that close, just thinking ahead. I have finished the wiring and everything works including the engine turning over. The family thinks I can make the Madisonville wooden boat festival in October but I can't finish it in 3 months. I will surely make next years, LOL.
Re: Monaco Restart
Look what Josh is doing on his boat regarding the cutwater and the bow eye. Really neat.
viewtopic.php?f=29&t=27058
Rich Coey
Re: Monaco Restart
Post by Rich Coey »
If you install a true lifting eye with your winch setup high, you do not need a bow eye. This is how the original boats were setup. Just me, but I would not put a bow eye through a cutwater.
Rich
speedracer
Re: Monaco Restart
Understood concerning a true lifting eye. My boat is not going to follow the original designs or finishes so adding a bow eye will not detract from it but I haven't decided 100% on the bow eye either way. I did take a look at what Josh did with his. Very nice.
speedracer
Re: Monaco Restart
Good evening. I haven’t posted in a while so I thought I would update my forum string.
Got 98% of the wiring complete now with no mistakes. Lights, blower, bilges, etc all work. I couldn’t keep my fingers off the key so I tried to turn the engine over. Dead - nothing. Everything looked right so I went to the engine manual. First thing it said to check – “Make sure the transmission is in neutral”. It wasn’t. I put it in neutral and she turned over immediately. What an awesome feeling. I felt like Dr. Frankenstein.
Seat are now 95% complete. I’m not sure I’ve got them built correctly to accept the upholstery around the cockpit edges (I’m sure there’s a name for that) so I’ll have to study on that before getting to that step. I noticed the boat (Innocence) built by Butch has wood around the cockpit edges. I kind of like that look but haven’t decided. One up side to that design is that the seats may be able to go out to the upholsterer without the boat going too. For the seats I’ve decided upon 3” and 2” foam for the bottoms and backs respectively based on other’s advice.
Completed the ceilings except for a few coats of finish.
Also completed the throttle/shifter with the cables. I had ran most of the electrical wire and steering hydraulic lines right where the controller had to go. Luckily I had enough slack to re-route everything hirer in the side wall so it worked out very nicely. The installation of the throttle/shifter was quite labor intensive. Lot of cutting trial fitting, cutting, trial fitting, cardboard patterns, etc. I ended up making a steel mount for it which makes it very firm. I’m very satisfied with the location and smooth action of the unit.
The dash with the gauges and switches is finished except for final attachment to the boat.
I had a great visit with Bayou Bengal a week or so ago. He was kind enough to give me his left over piece of SS for me to use on my boat for the cutwater and such. We talked for quite a while and he gave me a tour of his boat. It was super nice so I asked him who designed it was. He said it was a “Jeff” design. I didn’t catch what he said or the joke at first. After being impressed with the boat I asked again. As it turns out, he did probably 90% of the design himself! The boat is quite impressive. Hats off to you Bayou Bengal and thanks for the tour.
Still plenty of work to do but I can see the light at the end of the tunnel now.
Enjoy the photos and thanks again to everyone on the forum.
Front seat with completed contol
Complete control before ceiling
Dash board with gauges
speedracer
Re: Monaco Restart
Some more photos.
SS thanks to Bayou Bengal
Engine hatch with scoop
Overhead view of the engine compartment
speedracer
Re: Monaco Restart
More photos.
Over all view from bow position
Over all view from aft position
NAMEngJS
Re: Monaco Restart
Post by NAMEngJS »
Looking great! Can't wait to see it at the Wooden Boat Festival. Not to add a deadline for you :wink:
-Juan Suarez
BayouBengal
Re: Monaco Restart
All very neat and professional looking, and congrats on the engine turn; that is always exciting. Look forward to seeing your decking with the engine scoop and I suppose some additional type of elevation change to accommodate your speedometer and tach.
