I'm a Boat Builder! G-L Ski Tow under construction!
rleete
Re: I'm a Boat Builder! G-L Ski Tow under construction!
Postby rleete » Wed Oct 04, 2017 6:21 am
PB Blaster is pretty good, but if you want a miracle, you need to make your own. A 50/50 mix of acetone (available at auto parts stores) and automatic transmission fluid (ATF) works wonders. As a car guy in the rust belt, this stuff has saved my sanity more times than I can count.
Harbor Freight used to sell a refillable spray can, but I can't seem to find it there anymore. If you do mix it up in refillable spray bottle, you need to shake it up before use, as it separates fairly quickly.
Mark-NJ
Postby Mark-NJ » Wed Oct 04, 2017 12:35 pm
I have acetone & ATF on the shelf. I'll mix some up & see what happens. So far, I'm nowhere. That includes heating it with a torch.
At this point, I'll try anything!
Users browsing this forum: No registered users and 10 guests
