Stretched Flying Saucer Build
polarisman14
Re: Stretched Flying Saucer Build
Postby polarisman14 » Thu Sep 25, 2014 11:11 am
Quick update: I think I may have finally diagnosed the intermittent spark issue with my outboard. I pulled the flywheel after seeing that the spark issue stayed with the top cylinder even after swapping the coils around, and noticed that one of the NEW point assemblies from Mercury quicksilver was sticking open. Swapped the stock one in so we'll see if that fixes it.
polarisman14
Postby polarisman14 » Wed Oct 01, 2014 9:29 am
Finally! That appears to have fixed the problem. I put the new points in on Sunday and ran the boat around for a solid half hour to 45 minutes with 0 issues, even when trying my best to recreate the problem. I will be buying a new set of points from a different supplier known to have no manufacturing defects, and will keep the ones I have as spares...Just in time for the season to end. They will be drawing the water down on the lake I live across from on Oct. 13th. At least I will go into the off-season motivated to work on my Flying Saucer.
polarisman14
Postby polarisman14 » Thu May 28, 2015 2:37 am
Just wanted to post up a long-overdue update. I have continued making improvements/repairs to my 35hp outboard and it is now ready as a donor motor--that's part of the reason why I haven't worked on the boat too much. I've been busy enjoying the donor boat! Oh well.
I had a wooden boatbuilder that thankfully lives 10 minutes from me come over yesterday to look over the boat and give me a quote on finishing the fairing process for me. Basically, if it's under $500 I am going to pull the trigger just to have the peace of mind that comes with a properly faired hull. The planking isn't nearly as intimidating to me (besides the transition joints) as fairing because I know if this step isn't done properly the boat will ride and look like garbage. He showed me how he would fair a boat of this size as well so if it's too rich for my blood I can still do it myself. I'm just in way over my head and wanted to get another option. I'm still alive! :P
polarisman14
Postby polarisman14 » Mon Nov 06, 2017 1:16 pm
Hey guys,
I decided to throw in the towel on this. It is way above my knowledge base, room, tools, money, etc. If someone wants a killer deal on everything I have for it (well overhalf the materials to build the whole boat, interior, seats, etc.) please check in the For Sale sub-forum.
Thanks for all your support through the process...I'll be back eventually.
Postby vupilot » Mon Nov 06, 2017 4:55 pm
Matt,
Sorry to hear that. I looked at your pics in the ad, It appears the work you have done is done quite well. I hope someone will finish the project. Its a heck of a head start. My wife is glad you dont live closer, I am out of garage space anyway. :roll: I can understand the desire to have your space back and how having kids can really effect having the time to build but I feel from looking at your work you have the ability.
polarisman14
Postby polarisman14 » Tue Nov 07, 2017 5:47 am
Thanks for the kind words. More than anything, I am trying to simplify everything and consolidate all of my projects to stuff that is completed or only needs small details to be perfect. I bought a 17.5' boat for the family to use to get the kids into boating that is already good to go and am trying to wrap up some other odds and ends. It's definitely got a lot of the hard work done already and still plenty of opportunity for personalization for the new owner.
Trout
Postby Trout » Tue Mar 13, 2018 3:03 am
Where can I purchase glass and stainless windscreen for flying saucer. All so steering wheel stainless, and deck hardware.
Cheers
Peter
Postby vupilot » Tue Mar 13, 2018 5:16 pm
Many of those items are available right here through Glen-L. The rest you can find from various vendors online. This topic comes up quite often so you can use the search function of this forum and should find lots of info on windshield brackets, etc.
The glass will be custom to each boat so you will need to cut a template out of wood then have the glass cut. You can also use poly carbonate material instead of glass.
Users browsing this forum: No registered users and 9 guests
