I guess it's time to come out of the closet!Bartender 24
Re: I guess it's time to come out of the closet!Bartender 24
Post by Roberta » Thu Dec 28, 2017 12:21 pm
Good to hear, Bill!!
Roberta :D :D :D :D
JoeM
Post by JoeM » Thu Dec 28, 2017 12:29 pm
Very happy to hear that Bill! I wish it continues and you are able to get back to your normal life soon!
Post by Bill Edmundson » Thu Feb 08, 2018 10:42 am
The doctor gave me the all clear on my wrist. But, in the three months that I've been limited my upper body is noticeably weaker. I'll work on that. but, I'm free at last!
Now to that long checklist that has been put off!
Post by Roberta » Thu Feb 08, 2018 11:08 am
Good news Bill. Can I send you the minI Torpedo hull to sand when I get back? Light sanding will help you get back into shape.
Roberta :lol:
Post by Bill Edmundson » Thu Feb 08, 2018 12:11 pm
Always thoughtful... Should I use the big belt sander?
Post by Roberta » Thu Feb 08, 2018 1:18 pm
:lol: :lol: :lol:
Post by vupilot » Thu Feb 08, 2018 4:55 pm
Great BIll! Im sure your honey-do list will work out your weakened upper body quite nicely.
Post by Bill Edmundson » Thu Feb 08, 2018 5:43 pm
Chris
I see Heather has taught you well, my son.
Post by Bill Edmundson » Thu Mar 22, 2018 8:34 am
I finally got back to the boat. Three months of being down with arm, bad weather, and living 260 miles from the boat has caused not much to be done.
This week I finally fixed the gas gauges. The port tank now reads on the port gauge.
I put a switch in the NEMA2000 communication system. It was draining the batteries.
In finding out what was draining the batteries, I disconnected the Auto Charging Relay. I got the ACR reconnected.
I washed the hull. It had a lot of mold and mildew.
I took the cabin sole out. I'll take those home to install and caulk the pull rings.
It was way too windy here to put the boat in the water. 15 to 20 MPH wind makes it almost impossible to get into a slip. And it's no fun to run in. I still have a good list of things to do!
Post by hoodman » Thu Mar 22, 2018 11:00 am
Those pesky electronics always want to suck a little power even when they're off.
chugalug
Post by chugalug » Thu Mar 22, 2018 1:06 pm
:D A friend of mine at work,uses power cable connections from heavy-duty welders to connect and disconnect his battery on his old car.guess he got tired of coming out to a dead car.
Post by Bill Edmundson » Tue May 15, 2018 3:27 pm
Well, I finally got the Francis Lauren back in the water. She ran great!
Good news:
I had a problem with low speed wondering. I put a small skeg at the aft end of the keel, 2"high x 12" long. Remarkable improvement!
Fuel gauges now read port on the port and starboard reads on starboard.
Bad news:
The Garboard drains leak! I'm going to take them out and plug the holes. I never used them anyway. Seemed like a good idea at the time.
Today I hit the dumpster with the trailer fender and bent the shit out of it. Now, something else to do!
Lots of mildew to clean up.
Now the condo has poly-brutal plumbing that has to be replaced.
neel thompson
Post by neel thompson » Tue May 15, 2018 3:34 pm
Happy to hear the boat is running good.... Sorry to hear about the other stuff.... Did you do any damage to the dumpster?
Post by Bill Edmundson » Tue May 15, 2018 3:59 pm
Neel
The damn dumpster didn't even know it was hit! :lol: My trailer is useable, But, I don't want to take it on a road trip!
Post by vupilot » Tue May 15, 2018 7:47 pm
A friend did that to his trailer fender too. He just cut the bent section off at an angle. Then cut the other side to match, never would have known if he didnt point it out.
