Tom's Tahoe
Re: Tom's Tahoe
The rump on this boat is going to be something really special.
Re: Tom's Tahoe
Post by TomB »
Hey Matt, "rump", I like it, more friendly sounding than "stern"!
I decided to stick with seven plank courses and started planking at the sheer. I studied a number of methods and I may have settled on the absolute slowest way possible, almost entirely with a hand plane to spile each plank. Each piece gets test fit too many times to count as I try to avoid mistakes that I will notice.
I am planking one strip all the way around starting at the stem and working both ways, concentrating on alignment and tight joints.
I lightly sanded after the second course to see what the joints will look like.
The third course is almost ready to glue in place. I will slip planks behind it to get a joint line for the next course of planking.
Happy to be covering the plywood,
DaveM
Re: Tom's Tahoe
Post by DaveM »
Your planking looks good, your method and installation is very similar to what I have done on a Tahoe 23. It is nice to have gravity help. One thing I found interesting was that my butt joints on the bow sections had to be visually squared for appearance, meaning put it on - stand back and look - ok square. On the straight sections aft I could use a square.
Re: Tom's Tahoe
Post by TomB »
Thanks Dave. I am using a square set to the spile line and mark a cut line, then flip the square to come at the butt joint from the other side which always marks a slightly different cut line, then I split the difference and cut. In essence, set the butt joint on the radial line of the curved/spiled plank. Then I step back and have a look. Interesting stuff.
Re: Tom's Tahoe
Post by TomB »
This is the spiling method I am following. Use a card to move the spile line up.
Slip a new board behind the board ready to put on the boat and mark the bottom of the new board. Cut the bottom of the board to shape. Put it back on the boat and transfer the spile line down using the card.
Cut the top of the new board to shape. Flip the new board to the other side and check it there too. If it fits, use it for a template for a board on the other side. I glue the bottom course down after a full course is roughed out. The glued down course moves a little so no need to get the too perfect on the rough out. After the glue up is cleaned up I finish tuning the next layer.
Rinse and repeat.
Re: Tom's Tahoe
Post by TomB »
I make a bunch of wood washer and backed them with packing tape to cushion the staple during gluing. About 80% get busted up removing the staples after the glue sets. So I switched to the staple through rope method. I find a few wood washers with a lot of rope works best for met.
Three courses down, four to go, plus the bottom, and the holes in the bottom, and a little sanding...and so on.
Re: Tom's Tahoe
Post by JimmY »
Looking great, Tom.
Thanks for sharing your methods, I'll refer back to this for the next boat.
neel thompson
Re: Tom's Tahoe
Post by neel thompson »
Nice work Tom..... You are using the exact same method of planking that I used when I built the Gentry. It made sense to me to start from the bottom and work my way up. The only difference is that I used a Raptor brad gun and nailed through a batten to hold the bottom of the plank to the hull while I slipped next piece under the top. Then when I had it marked, I tapped the batten lightly with a hammer to release the plank for gluing. As a side note, you would be challenged to find staple holes from the rope/staple method.... I plan to use the same process on my current build, except I may use the Raptor staple gun through rope so I don't have to pull staples. I have to experiment with that first.
Re: Tom's Tahoe
Post by TomB »
Thanks for the kind words Jim and Neel. My grandfather was a good teacher. He used whatever was in his pocket as a gauge, a nickel is the proper space around a door, dimes for window sash, paper money between guide block and band saw blade, and a business card to transfer lines so you can see them when coping a board. I’ve also seen many great tidbits on the forum. So this is the method I use for this task, but far from an original method. Heck, I probably picked up some of it from you two.
I’m getting ready to make some hull finish mockups. I am going to include raptor staples, staple holes, and FamoWood to see how they look under stain and epoxy top coats.
I’m old enough to remember when radios and heaters where options for pickups. Now formerly optional skeg and spray rails appear on nearly every boat. I see that most ski boats use a ski fin rather than a skeg and I see a few fins on the forum. For those with skegs and fins, what’s your recommendation? How do they affect performance and handling?
Re: Tom's Tahoe
Tom, I don't think I've seen a lot of skegs on the inboard designs. Since the thrust off the prop is always in line with the center of the boat it's probably not necessary. On an outboard if you have a flat bottom you can tend to slide in a high-speed turn which is an interesting sensation or quite scary. My jon boat would do that on occasion, the remedy was less throttle. I'll let you know how my Geronimo tracks with the rather long skeg after launch, but there's no way to do an A-B comparison.
Re: Tom's Tahoe
Post by TomB »
I dug around a little more on the skeg/ski fin issue. Bill Edmondson, has a skeg but wrote to the effect that it would be wise to hold off and see how the boat handles. So that's the plan.
Re: Tom's Tahoe
Post by TomB »
It’s time for a science experiment.
Most of the hull is coming from the same log and the resulting veneer is mostly uniform in color. Sadly, there isn’t quite enough so I will end up with a few lighter planks. I have been using metal staples and the resulting holes mostly, but not always disappear. So far, I have been able to avoid gaps between planks but I want to experiment with how best to deal with the staple holes and any gaps I may discover during sanding.
I made five samples with a dark and light plank edge epoxied to a piece of pine strapping. Each dark plank got metal staples and each light plank got Raptor staples.
The staple holes are still noticeable after removing the metal staples, but I enlarged a couple of holes with a nail set and filled the holes and an intentional gap between planks with FamoWood (see red arrow). The blue arrow points to Raptor staple legs.
Then I used an RO sander with P80 paper and applied the stain.
I want to learn, what color I like best, if can I minimize the striping between light and dark boards, if FamoWood takes stain, if the “filler” in the stain fills the staple holes (if not, what is the effect of water on the holes), and what do the Raptor staple legs look like after stain and epoxy.
Re: Tom's Tahoe
Post by Jimbob »
I used raptor brads on the final planking. I got the dark brown ones, eventhough the natural colored ones take stain. Was not too big of a concern as the brads were set into the mahogany and Famowood was applied to the small holes. Famowood takes stain just fine. I don't think I would use the raptor staples on the final planking, it may create dents in the mahogany.
Re: Tom's Tahoe
Post by TomB »
I agree. I "hover stapled" holding the stapler off the work for the sample board. I would use wood washers for the real thing. My hull planking is all pulled metal staples but I wanted to see if they took stain. So far they do...unless the epoxy washes the stain off? Tom
Re: Tom's Tahoe
Have you tried a hot iron and damp cloth over the staple holes? It might get them to close up.
