20ft Texas Barrel
Re: 20ft Texas Barrel
That's a great idea, Matt!
I've been climbing in over the transom because of the lower opening from the outboard cutout. However, I will be adding the motorwell soon so that option is going to go away and I too will have to clamber over the side of the boat to get in. My boat is pretty tall and this would require a three step ladder or step stool to accomplish. Then there is the problem of getting down on the inside. I can just do it, but my wife cannot. For construction, I am going to get a small step stool for the inside of the boat, but when finished, she will have foldaway steps on each side to make it easier to get inside.
I like your idea Matt, however, It would be too low for my boat. By the way, I think the 500 times you mentioned is probably a bit low!
You got room under the deck for one of these?
No, but I was thinking about 100hp shot from the bottle of juice for that glass water drag race.
Need a little transmission education . I ended up with a PCM40 1.23:1 transmission with a 9 degree down angle. Gear reduction probably not really necessary on a boat the size of a Barrelback. The current prop diameter and pitch with a 1.23:1 trans will be a stump pulling set up, right? May need more pitch for cruising, yes?
Pros, Cons of reduction gear trans on a Barrelback? Neel, Roberta, Bill,..etc... What do y’all think?
Matt... I would send a PM to Mr. Hot Rod (Paul Kane). He is the expert when it comes to transmissions and props. On my Gentry I have a 1:1 transmission with a 13X15 three blade prop..... That is with 310 HP. I would think a 13X13 prop would be good for your setup. But that would be my guess if you were going with a 1:1 transmission. When you throw that 1.23 reduction in there, that is the end for me....I think Roberta may have a reduction gear on her Torpedo and I'm pretty sure it is a down angle trans. But she does have way more HP than either of us !!
- Bill Edmundson
- Contact:
I run a 13x16 w/1.23:1 8*down angle. The diesel is 115hp and will turn 3900 rpm. The Tahoe will run 38 to 39 mph. With a little more hp and a little more rpm, the 13x13 may be fine. I would try the prop that you have first. It won't cost you anything to try it.
Torque wise the diesel equals about the same as a 175hp gasoline engine.
Ok, thanks for the info. This donor boat is working out great, even if the prop isn’t the perfect diameter/pitch it gives me a free starting place. Specs say the Supra ski boat weighs 2350lbs, Barrelback won’t be any heavier. Same engine and prop pushing about the same size boat....it passes the TLAR test.
I have just enough humility to share my boat construction failures as well as successes. I tacked the winch up with some little screws and forgot to go back with the big lag bolts before attempting the flip. Enjoy the video.
https://youtu.be/OCwcYjPmBRI
- Bill Edmundson
- Contact:
That hurt!
Better it should fall from that angle than when it was further over and would have landed on the hull itself. No damage, hopefully?
All is fine, only a ruffled ego.
That'll make your navel pucker
- Mr Hot Rod
- Contact:
We field a lot of questions about inboard transmission gearing and propeller sizing.Neel Thompson wrote:Matt... I would send a PM to Mr. Hot Rod (Paul Kane).
Brad Tucker had a similar installation on his Tahoe 23 :
- Topic :Tahoe 23 prop size ? by Brad Tucker
- Shaft HP VS Speed Calculator
- Diameter-HP-RPM Formula spreadsheet
Related Links
- Topic : Propping the Monte Carlo by Brian
- Propeller And Gearing Calculator
- Determining Diameter from HP and RPM
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
Glen-L Hot Rod build thread
Glen-L Boat Video Directory
