Somerset, KY Gentry
Re: Somerset, KY Gentry
Post by mrintense » Fri Aug 16, 2019 4:10 pm
CarlM wrote:
Thu Aug 15, 2019 1:26 pm
Thanks Neel and Bill!! I think I will go ahead and add some in there just in case I need the support or as Bill said to screw into. You guys and this forum as a whole are best I couldn't imagine doing this without the help!!!!......Carl
This is the secret sauce of Glen L builds and I think it explains why so many of these boats actually get finished. :D :D :D
Carl's Vera Cruise Build
CarlM
Post by CarlM » Tue Jan 14, 2020 7:51 pm
It seems I am consistently horrible at making updates on my progress. I am happily chugging along on the build. The frames were completely faired. Two layers of 1/4" plywood was installed and faired. The final layer of 1/8" mahogany was installed. I ran out of mahogany so I used leftover plywood for the bottom which will be painted. The plywood was 1/4" so it had to be planed down close to 1/8". I then ran it through the drum sander to get it to exact thickness. I was quite impressed with the quality of the plywood. The surfaced side had to be marked so I wouldn't confuse it with the factory side.
I still have not acquired the motor. I believe I will try to find a used boat as a donor. I will get a 350 or a 351, with that knowledge can I still drill the shaft hole? Can the shaft diameter be determined? Any input would be appreciated greatly........Thanks...........Carl
neel thompson
Post by neel thompson » Wed Jan 15, 2020 3:35 am
Carl.... I used a 1" shaft on my Gentry and it was coupled to a small block 350 cu.in. motor. Of course, the shaft hole will need to be drilled somewhat larger than 1". Most drill the hole large enough to put a fiberglass tube in it and allowing for some clearance around the shaft inside the tube. Hope that helps.
Neel
CarlM
Post by CarlM » Wed Jan 15, 2020 8:50 am
Thanks Neel I appreciate your input. I wonder if that 1" shaft will also work with a 351. I am assuming it will with a possible alteration to the transmission. But I am still a little unsure.
monitor
Post by monitor » Wed Jan 15, 2020 9:27 am
Carl. Come by and take a look at my engine/prop shaft layout. It will help to see it in person.
I think you will need to make a scale drawing and template of the engine you expect to use. Combined with the info the plans give you, will get you close enough that changing the shaft length will let you fine tune the installation....my 2 cents, for what it's worth.
Your boat it looking good!
Jim Kinsella
Post by DrBryanJ » Wed Jan 15, 2020 9:51 am
Carl: Glad I could help. Your gentry is looking sweet. Maybe when we are all finished, Jim with his barrelback, you and I can meet at one of the great lakes in Kentucky with our boats.
CarlM
Post by CarlM » Wed Jan 15, 2020 10:02 am
Thanks Jim I will give you a call soon and set it up. I think looking at your setup will help a lot.
Dr.B that sounds like a good idea , a little regional meet up if you will.
Post by Bill Edmundson » Wed Jan 15, 2020 10:11 am
On shaft diameter the limiting factor is prop diameter. The 1" shaft will take up to a 13" dia. I know, maybe 14". Without going to a custom prop, about the most you can go is 4000 shaft rpm on a 12" prop. Max rpm goes down as dia. goes up.
This all works with engine rpm, gear ratio, prop dia., and prop. pitch.
monitor
Post by monitor » Wed Jan 15, 2020 10:16 am
I'm in Brian!
Jim Kinsella
CarlM
Post by CarlM » Wed Jan 15, 2020 10:27 am
Thanks Bill. I believe I have read you say that once before. My current concern is whether the 1" or 1 1/8" prop shaft diameter will be interchangeable with either engine setup as far as the actual mounting to the engine/ transmission. If that makes any sense. I believe I should be using the 1" diameter but I don't want this decision to bite me later.
Post by Bill Edmundson » Wed Jan 15, 2020 10:37 am
One thing. You want the prop to be a little less than 1 shaft diameter from prop to strut. Just ask Neel! Shaft dia. matches with the prop. not the engine.
CarlM
Post by CarlM » Wed Jan 15, 2020 10:43 am
I read about that little nightmare. I'm doing my best to learn from the group's issues and mishaps.
monitor
Post by monitor » Wed Jan 15, 2020 10:50 am
Carl. The shaft hubs that connect to the tranny hubs are the same on my 1-1/8" shaft ford setup and the 1" shaft chevy setup. Interchangable.
Jim Kinsella
CarlM
Post by CarlM » Wed Jan 15, 2020 10:58 am
Thanks Jim that was exactly what I was trying to figure out. I think I was about to go blind trying to research that. I still want to make the trip up to see your masterpiece in progress.
Sarnian
Post by Sarnian » Wed Jan 15, 2020 11:10 am
Carl - you've made amazing progress in such a short time. Looking great! I'm really intrigued by building a boat with an inboard - seems to add a whole other level.
