It is currently Mon May 20, 2013 8:15 am
 Post subject: Waterlodge build project
PostPosted: Thu Nov 15, 2007 8:38 am
I have begun the Waterlodge project and I have a couple questions.
Are the cross spalls connected to the building form(and if so how) or are they free floating?
Also, I plan to side the housing with vertical cedar siding over 1/2" ply, any problems with this?
Chris
 Post subject:
PostPosted: Fri Nov 30, 2007 11:06 am
Chris,
The Cross Spalls are attached to the set up members--they are temporary, so only fasten, not glue. We would recommend using 2x2 blocking to fasten them.
As for the cedar siding--using this in addition to the 1/2" plywood would make it quite heavy. We would suggest using thinner plywood or just the siding.
Gayle Brantuk
Vice President
Glen-L Marine
 Post subject: Motorwell changes
PostPosted: Fri Jan 04, 2008 2:23 pm
Hello all,
It's been a while since my last posting, quite a while actually.
I have also purchased the Waterlodge plans and will be starting soon; after reviewing the plans I came across a question for the group concerning the motorwell/bracket.
Is there any reason on this boat why I couldn't TIG weld the entire assembly out of aluminum tubing, powder coat it and install as stated in the plans (with a resilient marine bedding) and hot dipped galv. bolts? Dimensions would remain the same as would the plywood transom clamp.
Just a thought as I have access to quite a bit of aluminum...
Any thoughts?
Don Gilliland
