It is currently Sun May 19, 2013 5:31 am
 Post subject: Barrelback 19 framing
PostPosted: Tue Aug 05, 2008 1:13 pm
I purchased a set of plans from Glen L and after reviewing them have a question regarding the framing.
The instructions indicate the bottom frame member runs chine to chine, however the plans appear to show the vertcal running from chine to sheer. Can any one tell me which is correct.
 Post subject:
PostPosted: Tue Aug 05, 2008 2:09 pm
On my Monaco, I believe I ran the vertical from chine to sheer. I also filled the void between the plywood gusset creating a solid joint. Probably overkill, but I just did not like having that void.
David
 Post subject:
PostPosted: Wed Aug 06, 2008 9:37 am
David Thank you for your reply.
cron
