It is currently Thu May 23, 2013 6:50 am
 Post subject: What To use
PostPosted: Fri Nov 21, 2008 3:10 pm
Hello All,
I'm new to this so I have already asked a lot of questions and got a lot of good feedback. So I need to get this straight I use Poxy grip to build my frames and? Then I use the poxy shield for fiber glassing and? If you could help me out that would be great! Thanks
 Post subject:
PostPosted: Fri Nov 21, 2008 5:14 pm
poxy-grip anywhere you need a glue to bond two or more pieces,poxy-sheild for coating ,sealing & fiberglassing
 Post subject:
PostPosted: Fri Nov 21, 2008 5:52 pm
Poxy-shield can also be used as the glue if you add the fillers/thickeners.
The poxygrip is already thick, so you dont need the add the fillers.
 Post subject:
PostPosted: Mon Nov 24, 2008 1:27 pm
I have used both poxy grip and shield, and would recommend getting more shield and forgo because of the above comment about thickening shield into a usable glue.
Don't get me wrong, I really liked using the grip, it just seems as though there is a ton more encapsulating, glassing, etc that requires shield.
