upspirate...hehe...you're right, that was me getting off track - I'm thinking about doing that with my '88 so I was thinking 'out loud' Except for the cab-and-chassis bit, I think the rest of the thoughts apply just as well to a trailer as a coach body though.
The conversion van was just another option to throw into the mix that might be a viable alternative provided that a)the bench seats have enough lap belts to be legal with 6-8 pax, and b) the conversion itself is robust enough, remembering that he wants to use his rig on logging roads.
Renting one is a great idea. Let someone else's ceiling-mounted tv come crashing to the floor while rolling over a washboard!
When I was doing mine, I crawled around the display units at dealer lots for a while. I was blown away to see things like OSB ('chipboard') in lockers that would be the equivalent of cockpit lockers in a sailboat - i.e. the outside of the same locker is exposed to road spray from the tow vehicle and right where you'd keep chocks, tie-downs etc...wet stuff. Did I mention the tv secured to the flipdown mount with four 1/4" bolts but the mount screwed to the (~1/8") headliner with half a dozen #10 wood screws ? I assume (and hope) there was a plywood backer behind the headliner, but I would have used a much more robust attachment given the potential moment arm of a ~10lb bouncing tv. These things really are built on the cheap, apparently by monkeys sometimes.
Now, I'm not ripping on ALL RVs here, just the units most of us can afford to buy without a mortgage. I'd be happy to share a few bookmarks to some expedition-grade RVs that seem to be built like brick sh*thouses: welded structural frames, marine grade electrical components, ergonomics that actually make sense...etc.
Ironically, RV's are stupidly easy to build
well in your driveway if you can build and wire a small boat: there's no driveline to worry about, you're starting with a flat rectangular platform, you are contending with environmental moisture, not seawater and you can actually use a level and a square...
I think the biggest change I made was building mine from the outside inwards instead of from the inside out. They are typically built starting from the interior cabinetry and working outwards: cheap and easy to build, but a future nightmare for a tech or a restorer. Try getting the fridge out of a class C if the exterior access panel is too small to slide it through.
BTW, Happy Father's Day and summer solstice, everyone.
