[quote="DeltaDawg"] If my calcs are correct with the Yami F50TLR outboard I currently have the center of gravity at station 65 inches and the center of bouyancy at station 87 inches. As Bill stated in another post it would be ideal to have CG and CB on top of each other [quote]
Haaaa, calculations...ah yes...
That part is where I had no real clue when I started the boat. When I found the motor and decided on tanks and their location I emailed Glen-L and asked if the boat would handle them...they said yes, so I put 'em on. I did figure it was going to be a little heavy in the back, so my water tank is a 15 gallon, right up under the berths that I try to keep mostly full, so that helps a bit. I really had no idea about calculating weight distribution so I put things where the plans said, added my batteries and gas tanks and all the extra stuff, and hoped for the best! All in all, for a guy that had no idea what he was doing when I started, it worked out OK. For my Malahini however, I am going to try and make sure there is some rhyme or reason to what I am putting where, rather than my 'best guess'! Looking back, when I realize how little I actually knew about all this when I started, I am amazed that the boat turned out at all. I'm quite sure I'll be asking calculation questions in the not-too-distant-future!
