It is currently Tue Jun 18, 2013 8:33 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Squirt Build
PostPosted: Thu Dec 03, 2009 5:28 pm
Started my squirt. This is what I have so far after a weeks worth of hard work.
 Post subject: Re: Squirt Build
PostPosted: Thu Dec 03, 2009 5:29 pm
impressive progress :)
PostPosted: Thu Dec 03, 2009 5:33 pm
This boat building is so addictive. Once you start, its hard to stop. I worked late into the night.. 2 am or later. and man did I drag but at work the next day.
PostPosted: Thu Dec 03, 2009 5:48 pm
Very nice. Great progress. It took me several weeks of weekend building to get to that point. And good call on building your jig that high in the first place. I ended up putting coolers under the end of mine so I wouldn't have to stoop so much. :)
What kind of lumber are you using?
Photos of my Squirt build
El Toro I built with my Dad
PostPosted: Thu Dec 03, 2009 6:11 pm
One week!!! Really? You hand nothing cut a week ago? That's impressive indeed.
My Zip build log...
PostPosted: Thu Dec 03, 2009 7:21 pm
I'm using exterior grade plywood. And trust me, it took me at least 6 hours to cut out all those pieces. Man my wrist's and arms were so sore the next day. But it was worth it. Hopefully this weekend it will be planked and ready for fiberglassing next week. Because me and my wife are expecting are first baby in a few weeks. So I need to get as much done as possible, because when he gets here, there won't be much building for a little while. But I will keep you all posted on the build. Man this build is going much better than my first build. The peewee. I learned alot from that build. And this forum is awesome for any questions also. Thanks for all the great tips!
PostPosted: Thu Dec 03, 2009 8:18 pm
Exterior plywood for everything? Frames and chines and sheer and the while works?
PostPosted: Fri Dec 04, 2009 5:52 am
Just the frames. I used pine for the sheers and chines.
PostPosted: Fri Dec 04, 2009 8:56 am
Yea!! You are an inspiration!
can you post some Pee Wee pics please?
PostPosted: Fri Dec 04, 2009 11:55 am
Here's my first boat build. The PeeWee.
PostPosted: Fri Dec 04, 2009 12:02 pm
Found pics of the peewee here. Cute looking little boat.
Be sure to keep us up to date with pictures. I'm curious how the plywood frames work out for you. The question of whether or not they're a good idea comes up pretty often, it'll be good to have a data point. Did you use plywood frames in the peewee as well?
Edit: D'oh. You beat me to the pics. :)
PostPosted: Fri Dec 04, 2009 2:02 pm
I did use plywood on the peewee frames. I am using the same wood on the squirt. What are you using for your planking. I was going to use 1/4 inch ply. But I am afraid that I might have a flat spot in my hull where the butt joint is.
PostPosted: Fri Dec 04, 2009 2:16 pm
Me too. I know of at least 1 pro builder up here that is using ply for the frames though I would assume his boats are specifically designed for that. It will be nice to see how it works for the hobbyist.
PostPosted: Fri Dec 04, 2009 2:26 pm
Thanks for the pic....I remember your boat now! :oops: :wink: :D
PostPosted: Fri Dec 04, 2009 2:36 pm
I did'nt have any problems with the plywood frames. I encapsulated the whole inside of the peewee with epoxy before I painted it. Not quite sure why there is a question on using plywood for the frames. Any info would be helpfull. :) I'm on a limited budget. So I thought I would give it a try. Seems to work so far. :)
cron
