It is currently Wed Jun 19, 2013 11:52 am
Post new topic Reply to topic  [ 90 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: Electric Drive
PostPosted: Mon Dec 14, 2009 12:38 pm
I am building a 16' Hunk Finn pontoon for use on our pond. Wanted to know if anybody has built a Glen-L electric drive. Haven't decided on a drive system let, so all help welcomed.
Thanks, Chip
 Post subject: Re: Electric Drive
PostPosted: Mon Dec 14, 2009 1:34 pm
Just a thought Chip, but replacing the powerhead on an outboard with a golf cart motor would give you reverse without using a reversing solenoid pack. Using a longshaft o/b would work better off a pontoon deck anyway I think.
Oyster posted this link in another thread recently, but here it is again.
From what I've read, the outboard conversion's toughest part to DIY is machining a coupler to join the two shafts.
I think you could improve on the o/b conversion by ducting a slower, bigger prop as well rather than relying on the stock o/b cav plate, but we'll see in the spring after I scare up a motor and controller.
I haven't seen the E-drive plans other than what's posted on the website, but I think I'd want to have the mount welded up from steel or aluminum rather than ply once you consider how tight those belts would need to be to keep them from slipping under the torque of an electric motor spinning a prop from a dead stop, but that's JMHO.
All I've done so far on my own project is to get the donor o/b, but another option I've been thinking about instead is using these in a tunnel. On a pontoon, you could use a single motor on each hull with its own battery bank though it would be pretty exposed when beaching the boat. Though I suppose you could rig up a sort of hinged 'trim tab' mount that would be driven down into position by thrust but kick up if a skeg hits bottom...
I emailed Minn Kota a while ago about using these as for continuous-duty applications but their warranty wouldn't cover them in that case. I thought that was odd considering that they get used for trolling for hours at a time...
-Brian
- Yoda
PostPosted: Mon Dec 14, 2009 5:52 pm
Brian,
At this point I'm just considering my options. The main reason I asked about the electric drive is because I have a 1994 electric EZ-GO golf cart that my boys have driven the wheels off of. :lol: The motor controller and charger are still in good shape. Also, a friend of mine is an EZ-GO dealer who could help with wiring, etc..
I had already checked out Oyster's link. An electric outboard would be the easiest way to go. Explored that guy's whole web site, he is something else. Even looked at Minn Kota and Rayeo, but $$$$. Plug and play would be nice. Something different would be better.
Had a crazy thought this afternoon. What if I took the working from the golf cart and install midship or more forward at an angle, long drive shaft, extended strut and rudder. Now that would be something a pontoon with an inboard. :lol:
PostPosted: Mon Dec 14, 2009 6:00 pm
Grand Chillin - you are really starting to sound like one of this growing group of renegades. :lol:
If there is a will there is a way. But since you have now opened your mouth, we have to see it at the next Gathering. You will not be let off the hook :twisted:
PostPosted: Mon Dec 14, 2009 7:07 pm
I do wish that Falcon would come back for a bit. That man is the king of kings in regards to making the unorthodox plain. But you have the golf car to draw on, with a bit or marinizing of the fittings and wiring to make it safe for water use.
PostPosted: Mon Dec 14, 2009 8:44 pm
Dave,
I have followed this forum for about a year now and I am still in awe of the builds and builders. It is a honor to be mentioned in the same sentence as The Merry Band Of Renegades! :D Been told before this or that couldn't be done, only drove me harder. Hope you have finally kicked that stomuch bug. Felt for you.
Oyster,
I told y'all about my boys. Didn't tell you that this cart has already been swimming. :lol: One day I will have to tell the story about how another cart became stuck vertically up against a pine tree, yes vertically. Saw it with my own eyes, still don't know how. Going to give my buddy with the dealership a call tomorrow. He will get a kick out of this. He is a boat nut too.
PostPosted: Mon Dec 14, 2009 8:55 pm
Dave ,
Almost forgot about the gathering. Wanted to go this year, but already had something planned. Well, I didn't. :( I keep checking for a post of when and where for next year. Soon as I know it will be on my calender. Don't worry about loosening your drag, I want put up much of a fight. :lol:
PostPosted: Mon Dec 14, 2009 9:11 pm
Grand Chillin wrote:
Dave,
Hey, they accepted me, warts and all!!!!!!! :lol:
And yes, the work of these guys is something to behold.
PostPosted: Mon Dec 14, 2009 9:45 pm
And so is your work.
PostPosted: Tue Dec 15, 2009 4:46 am
This guy from Frisco was at the Gathering 09.
He says to use Motorguide I think the Electronics is in the motor so all you have to hook up is the controls.
PostPosted: Tue Dec 15, 2009 4:53 am
Thud- that is the boat that immediately came to mind. I was really impressed how he hid the battery cable making it look like a rope. Here is a top view.
PostPosted: Tue Dec 15, 2009 6:19 am
Anyone can use a Mini Kota motor. But thats not why we are here. We all come here and work way too hard to complicate all matters of boats and to overspend and continue to wonder aimlessly in our minds about these projects even while sitting in church worshiping to another God before us. :oops:
PostPosted: Tue Dec 15, 2009 10:07 am
Huh!!!!.
PostPosted: Tue Dec 15, 2009 10:15 am
Dave, it was a dig at the suggestion about the trolling motors - using a ready-made solution when the problem could be solved by mad-scientist bodgery and busted knuckles instead.
And very eloquently put, btw... :mrgreen:
-Brian
- Yoda
PostPosted: Tue Dec 15, 2009 10:49 am
I wonder if we could use wound up rubber bands like the old balsa wood airplanes...... :idea:
http://www.unitybuild.net
